Home > Puma (Tdci) > Charging problems
Thomjam
Norway 2007 Defender 110 Puma 2.2 SW Java Black
Charging problems
My Puma 2007 refuse to charge. They have replaced the altenator at the garage, but it did not fix the problem. The indicator lamp is lit when it should be lit, an all wires and such are intact. Now they suspect a problem with the ECU.
The engine is tuned at the garage some one year ago and has 130 000 km milage. (80778 miles)
Any suggestions on what the problem can be?
Thanks
Thom
Oslo, Norway
Post #429229 7th Jun 2015 2:16pm
the alternator voltage should read about 14.4v (when engine running)
the battery should be at least 12.2v (when engine stopped)
check your earth lead from the battery to the chassis under the car
check the relays under the seat and ensure they are all firmly in place
if there are no other signs, you'll need to get it on the diagnostics and have a look for any codes
good luck!
Post #429247 7th Jun 2015 3:30pm
Thomjam
Thank you.
Done that. Din not fix it. I guess there might be a problem with the ECU,but it does not indicate any problems. Strange problem...
Post #429257 7th Jun 2015 3:46pm
K9F
Having a quick glance at the diagram I believe the starter motor appears to be 'in series' with the alternator. I would perhaps have a look there if there were any issues perhaps? The two red cables attached to the starter motor should be linked internally within the starter motor itself. If this link is open it may cause the symptoms you describe. You mention the lamp is lit when it is supposed to be lit, does it also extinguish when it is supposed to extinguish? There is also ECU involvement but I am unsure what this is sorry.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429272 7th Jun 2015 4:40pm
munch90
main charging lead from alternator goes from back of alternator to starter main terminal , charge current is then taken back to battery via starter main live feed
test lead at back of alternator is live ( permament live ) if not check connection on starter
check alternator is charging by testing voltage on rear main terminal ( roughly 14.4v )
never known a ecu cause a charging problem , ( only time anything like that was with a cheap recon alternator that the ecu wouldn't control to switch on )
there a smart charge alternator controlled by ecu , but like said never seen a ecu cause charging problem
Post #429286 7th Jun 2015 5:45pm
Maybe you battery is expired ?
Will it hold a charge if you use a battery charger ?
Why do you think it's the ecu?
Post #429289 7th Jun 2015 5:51pm
K9F
This may help both Munch's and my explanations.....excuse the quality.
Steve the ECU involvement is the white cable purple stripe second shot to the alternator itself 'Altmon?!' (Alternator monitor perhaps?) Maybe just a theory but could it keep the alternator off line whilst cranking to prevent overload? Thumbs Up
Post #429295 7th Jun 2015 6:15pm
munch90
The ecu switches the alternator on after about 3-4 secs after starting
they call it a smart charge alternator
Post #429298 7th Jun 2015 6:29pm
K9F
Thumbs Up
Thanks Munch, pretty much as theorised! Thumbs Up Could be ECU related as the OP suggested then! Would need to get a voltmeter on that cable and the output of the alternator to see what the relationship is and expected outputs. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429301 7th Jun 2015 6:39pm
munch90
Doubt it would be ecu related , like said never seen it on any car ( but we are talking a defender here Rolling with laughter )and most stuff have smart charge now
my money would be on connections or cheap recon alternator
Post #429303 7th Jun 2015 6:46pm
K9F
Agree (I think). Definitely about the 'Defender' bit! Think the starter motor where the two cables are linked would be a good starting point (no pun intended). Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429309 7th Jun 2015 6:56pm
munch90
Yep agree about starter connection Thumbs Up
Post #429313 7th Jun 2015 7:03pm
munch90
Another slight possibility would be alternator pulley slipping as there a freewheel / clutch / over run pulley and when knackered can slip and not drive alternator , even though it looks like its turning ok
some new/recon alternator come with pulleys some without , so maybe a problem if the old pulley fitted on new alternator
Post #429318 7th Jun 2015 7:14pm
K9F
Thumbs Up
At least he now has a few more pointers that will nail the issue down hopefully, either way it'll need a voltmeter at the very least! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429321 7th Jun 2015 7:24pm
Thomjam
Thank you a lot guys! This is great! I will take the advice with me to the garage to morrow - they specialize on Land Rover, so I'm surprised they haven't worked it out. In the meantime I drive my 90 soft top, more reliable the 300 Tdi.
Will post when (?) problem is solved.
Thanks again
Thom
Post #429339 7th Jun 2015 9:09pm
