Home > Puma (Tdci) > Charging problems
Page 2 of 2 <12
From reading this thread from my point of view I think both K9F and Munch are correct.
I think the cable K9 has identified is most likely suspect and as munch suggests I too doubt it's anything to do with the ECU.
It's simply flagging up that there is a problem.
It could be the cable it's self or maybe more likely the connectors.
Checking all functions with a voltmeter / multimeter certainly would help.
I can see the alternator being turned on xx seconds after startup as munch mentions as I notice every time with my HU that it boots up about 4 seconds after the motor is running.
Good luck. Thumbs Up
Post #429342 7th Jun 2015 9:25pm
Just to add to my last post as a possible thing.
Before any work is done at all, disconnect the battery completely for half an hour then reconnect it and see what happens.
It might need the whole ECU / system to re-boot and recognise that there is no longer a problem.
If nothing else it might be worth trying as sometimes to power off completely for a while then back on will sort it's self out.
Post #429343 7th Jun 2015 9:28pm
Thomjam
Norway 2007 Defender 110 Puma 2.2 SW Java Black
Thank you all. I have talked to the guys at the garage, and we have agreed to replace the new alternator with a new original one, after they have tried all the alternatives you have suggested here. We'll see how that works out...
Post #429562 8th Jun 2015 6:17pm
Make sure they let you know exactly what was the problem. Thumbs Up Thumbs Up
Post #429570 8th Jun 2015 6:31pm
Thomjam
I will! And I hope it works out. Next step is to replace the ECU, they say. And if it's not that, the ECU is custom made for the car, and would be money out the window Confused
Btw the starter was replaced this Easter, so it has been a few things this winter. i put it on the charm account , can't other than love the Defender, though strange things happen with it. Perfect car in Norway.
Post #429576 8th Jun 2015 7:07pm
Thomjam
Changing the ECU solved the charging problem. They never found out what the exact problem was. Land Rover...
Post #435333 2nd Jul 2015 2:57pm
The alternator is ECU activated on a Puma.
Post #435339 2nd Jul 2015 3:41pm
Page 2 of 2 <12
