Home > Puma (Tdci) > Bizarre front lift. - Spring codes. |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
HI there,
I recently changed the front springs on my tdci 110. I used NRC9448 and NRC9449, which are for 110 Heavy Duty front, 130 Front Standard and 90 Rear. So if you used standard 110 front spring on your 90 rear, they will sag. There are also HD version of the 90 Rear. the color codes, I still remember, are Blue red for driver side and white yellow for passerger side Cheers Martin |
4th Jun 2015 6:09am |
Landyphil Member Since: 23 Jul 2012 Location: Lake District Posts: 87 |
Well just an update. It gets weirder.
Tonight I fitted a set of genuine REB500200 and 220's front springs. And the result was almost as bad as first time round. Big nose up attitude and as a result between 36-39mph huge amounts of growling vibration and below that speed on smooth tarmac you can feel it pulsing. I'd say there was something else majorly up except this vibration started the nanosecond I changed the front springs and if you happen to go over any undulations at around 36-39mph as the front suspension compresses the noise goes away and as it extends it gets worse. Can't find any play in the front prop and bizarrely the transfer box isn't to mad either for a Puma. So can I please please ask a favour of you dear people to make sure I'm not going mad. I'm running fairly new BFG AT's in 265/75R16 flavour. On level ground with no one in if I measure from vertically up through the front hub line to the lip of the wheel arch it's just over 900mm. In my view that's a lifted Defender! Hence all the propshaft vibration issues. Any help or advice is greatly appreciated. It's wearing very very thin. 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
15th Jun 2015 9:11pm |
