Home > Maintenance & Modifications > Leak
Leak
Getting a bit of a leak in the passenger footwell.
Appears to originate from the area of the metal retaining piece that hold the rubber mat in place nearer the door but more or less below the speaker.
Without investigating further what is the likely culprit?
Nothing on the drivers side at all...
I may have to remove the while dash sometime coming up to see if there is any Dynamat that is worth fitting so would be ideal to try and sort it out.
Ideas?
The air intake drain hole should n't be blocked as far as I'm aware but might be worth checking.
The rubber bung is removed from it already.
Post #428052 2nd Jun 2015 3:42pm
Happyoldgit
Screen frame to bulkhead seal, screen bracket bolt holes or possibly the join between the frame and bulkhead under the door seal itself? Pull the lower speaker etc for a looksee with a torch. Steve.
http://forums.lr4x4.com
Post #428067 2nd Jun 2015 4:12pm
Will do, seems like maybe the most likely the screen to bulkhead seal.
The screen brackets and bolt holes are too far to the left as is the door seals and there are no signs of moisture there.
(At least visible anyway)
So on this one I'm tending to think it's the seal between the frame and screen.
Hopefully I can see up there somehow as you suggested as long as there isn't something in the way. Laughing
I've had a little bit there for a while but not enough to worry about but today it's a fair bit.
I assume becuase the dry weather and warmth we've had he probably contracted the seal a touch and then this rain.
Thumbs Up
Post #428074 2nd Jun 2015 4:19pm
CatherineF
How about a new truck instead Steve? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #428081 2nd Jun 2015 4:35pm
gilarion
In my experience they leak worse than the old ones Whistle For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #428084 2nd Jun 2015 4:40pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Mine was leaking past the windscreen rubber the other day. Have a look over the top of the dash at the windscreen seal. You might see water here. Near where the heated screen connectors are if you have a heated screen?
Post #428099 2nd Jun 2015 5:44pm
Daz - I'll have a look see, I don't have a heated screen but none the less I know exactly where you mean. Thumbs Up
Post #428101 2nd Jun 2015 5:51pm
