Home > Maintenance & Modifications > Leak |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Screen frame to bulkhead seal, screen bracket bolt holes or possibly the join between the frame and bulkhead under the door seal itself? Pull the lower speaker etc for a looksee with a torch. Steve.
2nd Jun 2015 4:12pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20126 |
Will do, seems like maybe the most likely the screen to bulkhead seal.
The screen brackets and bolt holes are too far to the left as is the door seals and there are no signs of moisture there. (At least visible anyway) So on this one I'm tending to think it's the seal between the frame and screen. Hopefully I can see up there somehow as you suggested as long as there isn't something in the way. I've had a little bit there for a while but not enough to worry about but today it's a fair bit. I assume becuase the dry weather and warmth we've had he probably contracted the seal a touch and then this rain. |
2nd Jun 2015 4:19pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
How about a new truck instead Steve? 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
2nd Jun 2015 4:35pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5101 |
In my experience they leak worse than the old ones For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
2nd Jun 2015 4:40pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2025 |
Mine was leaking past the windscreen rubber the other day. Have a look over the top of the dash at the windscreen seal. You might see water here. Near where the heated screen connectors are if you have a heated screen?
2nd Jun 2015 5:44pm |
Daz - I'll have a look see, I don't have a heated screen but none the less I know exactly where you mean.
2nd Jun 2015 5:51pm |
