Home > Wheels & Tyres > Wheel nuts that STAY black? |
Yes, there are, but they're not cheap!
http://www.wrington.co.uk/landrover%20alloy%20wheel%20nuts.html Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
31st May 2015 8:40am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 |
.. £15 a nut! ouch! 2008 Defender 110 XS SW - M57N2 / 6HP28X
31st May 2015 8:42am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2651 |
plasti dipped mine over 2 years ago... wheels have been on / off @ LR to have the swivel changed under warranty about 3 times, new brakes all around and still looking fresh.
31st May 2015 8:43am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
£9.00 each |
31st May 2015 8:51am |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 |
Hmm, on that same website I found these (I run steel wheels):
http://www.wrington.co.uk/land%20rover%20s...0nuts.html It goes down from 15,- a nut to 12,- a wheel, that is more reasonable but still quite a considerable sum: 60,- for only a few nuts. May I'll try the plastidip first! Defender 130 HCPU Td5 MY2000 |
theres a little art to it, coat too thick and the socket will damage it, took me a few goes of trial and error
31st May 2015 8:54am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Boab does a set of black alloy wheel nuts for about £150 for a set of 23
Nakatanenga does a set of black steel wheel nuts for about 50 euros. Am not sure if both companies offer both alloy and steel wheel nuts. Brendan |
31st May 2015 9:06am |
Thanks for all the info, I will look into it!
The reason why I am considering Plastidip for the nuts, is that I have those ghastly (well, in my view) gold colored HD drive flanges that I was thinking of Plastidipping anyway. Kill two birds with one stone, right? At least it is cheap, I can always go for the more expensive options if it doesn't work out. It's just that I didn't expect the Plastidip coating to survive using a socket on 'm that well as they do in Likeomg's case. Defender 130 HCPU Td5 MY2000 |
31st May 2015 9:17am |
i've got rakeway upgraded drive flanges and quite like the gold look.. especially with the little 'R' on the caps... just didn't match with my gold
this is 2 years of plastic dipped nuts Click image to enlarge |
31st May 2015 9:27am |
Lookin' good!
Did you 'prep' the nuts in any way? Or should I simply degrease and give it a go? Defender 130 HCPU Td5 MY2000 |
31st May 2015 9:35am |
Hmmm, I just realized my nuts (wheel nuts, that is...) are open ended, so not closed at the end like yours. This might be a bit of a problem when plastidipping, or for the plastidip to last? Defender 130 HCPU Td5 MY2000
31st May 2015 9:43am |
tim1967 Member Since: 06 Jan 2015 Location: Essex Posts: 8 |
You can get plastic wheel nut covers in black for about £15/full set all in.
31st May 2015 6:57pm |
Great idea Tim, why didn't I think of that myself!? Defender 130 HCPU Td5 MY2000
31st May 2015 7:08pm |
Hmmm, I don't seem to find them in 27mm. All I can find is 17, 19 or 21mm...? Defender 130 HCPU Td5 MY2000
31st May 2015 7:37pm |
