Home > Technical > times to change clutch and flywheel TD5 90 and cost? |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Not sure about the TD5 but I just got my Puma done in about 6 hours for £661 and some change, new AP HD clutch, slave cylinder and single mass flywheel including labour all whilst away in the tin tent using an independent.
30th May 2015 10:43pm |
Landydefender1 Member Since: 13 May 2015 Location: East Yorkshire Posts: 63 |
Wonder if that's the same time ... Price as a TD5? They can't be that different?......... Can they?
31st May 2015 7:15am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
They work roughly on 10 hours labour I had a recent price of genuine £1480 and £1060 for a Valeo.
31st May 2015 7:58am |
Is the TD5 that different from a Puma?
31st May 2015 8:18am |
Pass never been near a puma yet ? The time is stripping everything out ,just to drop the box.You can get a valeo clutch,DMF and bearings for around £400. Genuine DMF is about £560 on its own !!!! Some take the engine out, others move it forward, others drop the box. Make sure you replace the spigot bearing at the same time.
31st May 2015 8:55am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
They're having a laugh. Td5 clutch and flywheel is a doddle to do. I used to do them in 3 hours on my own on the floor. Confident I could do one on the floor in 5 hours these days no probs.
31st May 2015 12:25pm |
might be worth a trip to yours then
31st May 2015 1:04pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I looked into it about 3 months ago when mine was slipping, I managed to sort it but the local garage quoted me approx 10 hours labour plus the cost of the clutch. They asked L/R about replacing it with a solid flywheel too, which I asked them to, but they said the local L/R dealer had not recommended doing this as it ended up being very noisy to the point of people returning to the dealers asking what's wrong, so stick with the dual mass.
I think it came to around £850 ish, plus there might be some seals, oils etc. They recommended Valeo parts |
31st May 2015 1:54pm |
Where in the UK are you? Will you do mine? Cheers |
31st May 2015 10:50pm |
