![]() | Home > Td5 > TD5 Clutch dual mass flywheel |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
Hi Jim, I used a sealy transmission adaptor that fits to a trolley jack, worked a treat. The transmission jack, if it's the one I'm thinking of you may struggle for clearance, as you will need to move it out of the way so that you can access to the clutch, just a thought.
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
My thoughts with this route is no need to take out the floor panels
Trolley jack adapter very good, however i did split the boxes to make life easier and only removed the transmission tunnel and the panel under the cubby box
