Home > Puma (Tdci) > Rear end rust issue. I need advice.
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
I'm looking for some help.
The back of my 2007 Puma 110 is looking rough...really rough. Since I have no plans on selling my beloved Landy I need to get it all fixed.
What is the bit called that has the 6 screws in it and all the holes? (I think its fibreglass?) Is that an expensive bit to replace? Just below the the holes and above the rear cross member there is a very rusty bit... Am I able to replace this also with out too much trouble? Or is it part of the floor?
Any advice to upgrade replacements would be appreciated so I don't have to do this again in the near future.
Richard
/Users/richard/Desktop/IMG_1323.jpg
Post #427088 29th May 2015 2:11pm
rleslie
Thats annoying, I can't even add the photo to the post.... its in my gallery.....
Post #427090 29th May 2015 2:18pm
ickle
Hells Teeth!
Have you been parking that on a salt water slip way? Shocked
Post #427092 29th May 2015 2:24pm
rleslie
The joys of Scottish winters, and salty roads for 5 months of the year.... Its not pretty!
Post #427093 29th May 2015 2:28pm
smb
Jesus!! And I thought my crossmember was bad Shocked
It is worthwhile every Defender of Series owner double checking all the nooks and crannies this year as some councils in light of previous criticism have been putting an unprecedented amount of salt on the roads this last Winter.
Post #427096 29th May 2015 2:38pm
Re: Rear end rust issue. I need advice.
rleslie wrote:
... What is the bit called that has the 6 screws in it and all the holes? (I think its fibreglass?) ...
If you means the painted strip immediately below the rear door, this is part of the rear floor/rear body assembly and is not easy to replace. It is not fibreglass, it is alloy like the rest of the body.
The rusty bit you describe as being between it and the rear crossmember is actually part of the rear crossmember - the 6 screws in the first bit secure the rear body to the crossmember.
There is unfortunately no gentle way to break the news - you have some major repairs shaping up there. Big Cry
Post #427097 29th May 2015 2:38pm
TJ101
Will agree, not a pretty sight !!
Think its a case of unbolting/screwing as much as you can, and see what you have left,,
As blackwolf,, a fair bit of work needs to be done,, sooner, rather thank later !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #427100 29th May 2015 2:58pm
Happyoldgit
Shocked Out of interest what is the history of the vehicle? Steve.
http://forums.lr4x4.com
Post #427268 30th May 2015 4:27pm
mikeh501
Heres my 4 point plan to fix your manky cross member. I think it will come up a treat with a bit of love.
1.) Unbolt everything from the crossmember like the step and tow hitch. Get them rust treated and painted up ready to put back on. Dinitrol RC900 rust converter primer and then topcoat with chassis black or something.
2.) Get a jet washer or better a steam cleaner and go to town on the whole back end especially the chassis and cross member.
3.) Once its all dried you can then set about the exterior of the cross member face. Strip what paints left, rust convert and primer it. Then top coat etc. You can remove those bolts which hold the cross member onto the body and replace with some stainless ones which will help down the line. The tub alloy portions will need some tlc. id start by properly cleaning all the gunk off and see whats left.
4.) Cross members rot inside out, so as bad as it looks its the inside which you need to protect most. You need to inject dinitrol ML3125 into all the interior box sections, then on the outside sections (but not the rear face) Dinitrol 4941 would be great. This stuff will make it all nice and black when looking through the wheel arches but most importantly will provide great protection next winter.
edit: just noticed your tub has holes in it where the bolts are! rust treatment wont fix that lol. if those are like that i dread to think what the rest of the vehicle is like underneath! good luck Thumbs Up
Post #427340 30th May 2015 9:55pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Good question and answers its on my list to do this summer.
Thanks.
Post #427483 31st May 2015 12:28pm
