Home > Maintenance & Modifications > Ashcroft Transmissions Gearbox Output Shaft Kit
Page 1 of 3 123>
AndrewS
Going to fit one of these whilst the 130 is in having a new clutch.
http://www.ashcroft-transmissions.co.uk/mt...t-kit.html
The reason for doing this is here.
http://www.defender2.net/forum/topic32931....p;start=60
Whilst in the dealers its also having:- New head gasket as its got an oil leak. New front diff pinion seal. Oil pump recall works. New bonnet, as the nut that holds the catch was welded on in the wrong place and the bonnet kept popping open.
Oh and they are fitting the bigger Bowler brakes for me Thumbs Up 130's have feeling's as well you know Smile
Post #426995 29th May 2015 5:37am
LR90XS2011
some work being done there, will be interested to know how the Ashcroft shaft goes and lasts DEFENDER 90 TDCI XS,
Post #426996 29th May 2015 5:57am
Naks
Jah, if only it wasn't R19 to the pound, I would also get the Ashcroft kit done. Big Cry --
Post #427025 29th May 2015 8:26am
need4speed
Knowing Ashcrofts it will probably outlive the rest of the Puma..
Certainly a million times better than the chocolate they're currently made of Whistle
Post #427043 29th May 2015 9:14am
jst
i ordered one of these which arrived last week to, will fit it when i do the clutch which at 51k miles it seems prudent to do! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #427044 29th May 2015 9:14am
T1G UP
i think mines ready for one. Had a clutch under warranty at 17k so got a few miles left in the old girl. When it goes does it do any damage apart from loss of drive?
Post #427055 29th May 2015 10:19am
Nice engineering by Ashcroft, and it's a permanent fix .. As Eric would say a reliability modification
Post #427058 29th May 2015 10:30am
munch90
aren't the Ashcroft ones standard ones converted ?
bpman Nice engineering by Ashcroft, and it's a permanent fix
how long have they been tested for ?
NOT saying they no good , they look good , but anyone have anyone have results from fitting the kit ?
Post #427062 29th May 2015 11:32am
Correct, they're standard parts machined to allow oil migration from the main gearbox.
I am not aware of anyone who's run an Ashcroft set for a significant mileage yet, and look forward to hearing feedback when someone does. I have no doubt that they'll work very well, but similarly the standard parts properly lubricated also seem pretty long-lasting.
T1G UP wrote:
... When it goes does it do any damage apart from loss of drive?
The only immediate damage is to the failed parts ... ... unless you happen to be on a level crossing, or the middle of a junction, or a motorway, etc, when it fails. In those cases, who knows? Thankfully it hasn't happened yet.
Post #427064 29th May 2015 11:41am
You're quite right munch, but given the issue is a non-greased joint and the Ashcroft kit feeds oil to the joint it should be good fix and Ashcroft quality Thumbs Up
Post #427079 29th May 2015 12:44pm
need4speed
Post #427091 29th May 2015 2:23pm
AndrewS
WoW the exact same link I posted in my original post at the start of the thread. Thud Rolling with laughter
Well I reckon as others do with Ashcrofts reputation and the fact that the joint will now be lubed up its a win win situation. Time will tell I suppose Thumbs Up 130's have feeling's as well you know Smile
Post #427112 29th May 2015 3:48pm
I can think of no finer testbed than Longshanks for a long term test of the Ashcroft Solution, and look forward to finding out how it fares.
Post #427121 29th May 2015 4:37pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
My factory splines let go suddenly when I was on a Motorway, luckily I was able to coast to the hard shoulder but it was scary.
Post #427131 29th May 2015 6:12pm
need4speed
Whoops. Sorry Andrew, my bad Wink
Post #427140 29th May 2015 7:41pm
Page 1 of 3 123>
