Home > Puma (Tdci) > Remap EML. |
Have you contacted the provider of your remap? It was only three weeks ago you had it done? The P1103 code is MAF related and is a 'nuisance code' if you do a search. I am no expert but I would start by removing the blank.
P1103 Mass Air Flow Sensor In Range But Higher Than Expected P0404 Exhaust Gas Recirculation "A" Control Circuit Range/Performance If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
21st May 2015 10:11pm |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 |
As above first port of call would be to get hold of the remap company, who did it for you? Any reputable company would be happy to help or advise I'm sure! 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
23rd May 2015 8:50am |
Maybe you should have contacted them first perhaps?
23rd May 2015 9:59am |
