Home > Technical > door hinge problem.
Page 2 of 2 <12
Green Machine
Am I understanding correctly that the J clip currently just has a standard hex nut in it? If so, presumably it didn't tighten up much before it started spinning and as it's a new nut and bolt should be pretty easy to undo again. Can't you just get a finger through the hole onto the nut, just to give it a tiny bit of resistance to be able to undo the bolt? Rubber glove might help to get more purchase on the nut with just one finger. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #424421 18th May 2015 12:18pm
shaggydog
If its stainless and put in dry it may have galled up in which case it will never properly undo as it basically friction welds itself together - stainless is a horrible material for fittings. All our high pressure pipework and fittings are stainless at work and unless you lube them up with some blue goop you will never get them apart in one piece!
Do you know anyone with a die grinder or cut off wheel? It may be best way to do it and carefully slice the bolt through and then making sure not to drop the captive nut or bolt into the bulkhead try and pick them out,
Alternatively try and drill the head but again stainless is a horrible material to work with so go carefully.
Also be careful of the bulkhead, its only 2mm thick laminated steel and bends very easily!
I had the other problem which was rusted seized nuts when I did my bulkhead repair so i can feel your pain!
Good luck Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #424422 18th May 2015 12:22pm
mk1collector
I can't remember off the top of my head but is there a hole under the trim on the inside of the pillar where you could get some small grips in to hold the nut while undoing the bolt? Ray
My build thread
Post #424423 18th May 2015 12:33pm
As Shaggy has said, the Stainless bolt is effectively welded to the Stainless nut, you will not get them apart.
Your only options are to drill out the head of the bolt - Stainless is harder than mild steel not softer, cut the hinge or cut the bolt.
If you can grip the nut in some way you will need to shear the bolt off, it won't unscrew.
We use a lot of Stainless fixings in my other business, horrible things !
Post #424431 18th May 2015 1:13pm
I despise stainless fixings - the experience of drilling them all out of my Patriot rack to replace with proper fixings almost drove me round the bend. Nothing but trouble.
Post #424436 18th May 2015 1:23pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Been here before!!
Sheet of hardboard (0.5m sq..ish)with an 8mm slot in it to the centre..
Drop in down between hinge and body..slot down.
Masking tape in place.
Nylon/plastic/wood wedge behind hinge to hold in place..and hacksaw bolt through.
( may have to sacrifice wedge)
Pretty straightforward really Thumbs Up
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #424448 18th May 2015 2:05pm
Likeomg
very straight forward actually, pry bar on the top of the hinge, cloth behind not to mark paintwork and just went at it with a 5mm key in a drill, out in 30 seconds.
Post #424641 18th May 2015 10:01pm
Likeomg
next question is...
whats the best way to line the door up?
Post #424643 18th May 2015 10:02pm
mk1collector
Wind window down, shut door onto catch fully then fit hinges loosely. Get someone to hold the door so the gap to the pillars is level front and back and then tighten hinges. Ray
My build thread
Post #424648 18th May 2015 10:17pm
Page 2 of 2 <12
