Home > Td5 > Central locking rear side doors
Double_R
England 2014 Defender 90 Puma 2.2 HT Corris Grey
I have factory installed central locking on a 110 Td5 and the rear passenger doors have both stopped locking/unlocking. I could understand it more if just one door wasn't working but is there some control or fuse that activates both the rear side doors? Both front doors and rear door are still fine.
Thanks Chris
Post #424406 18th May 2015 11:46am
mk1collector
The wires will have broken in the rubber boot inbetween the b post and door, it's quite a common problem Ray
My build thread
Post #424411 18th May 2015 11:59am
The usual reason is a broken wire in the rubber sheath between the door and the B post, although for both to fail simultaneously does seem to be a bit of a coincindence.
I don't myself know of any single point of failure which would affect just the second-row doors.
Post #424414 18th May 2015 12:02pm
Double_R
On both sides? Seems a bit of a coincidence...
Post #424415 18th May 2015 12:03pm
Double_R
Thanks, time to get the multimeter out by the sounds of it.
Post #424417 18th May 2015 12:07pm
mk1collector
Are you sure you just didn't notice one wasn't locking for a while? Ray
My build thread
Post #424424 18th May 2015 12:35pm
There is a connector inside the B post very close to the point where the rubber sleeve is fitted. If you are getting the correct lock and unlock energisations there, but the doors aren't locking and unlocking, then it is amost certainly the broken wire problem. It is unlikely that both actuators have failed simultaneously.
Post #424438 18th May 2015 1:27pm
theorangebandit
Mine did this so I then re greased all the door hinges with silicone spray grease, and all the latches and mechanisms. Problem solved clearly seized up. Give it q go
Post #424509 18th May 2015 5:09pm
