![]() | Home > Td5 > Central locking rear side doors |
The wires will have broken in the rubber boot inbetween the b post and door, it's quite a common problem Ray
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
The usual reason is a broken wire in the rubber sheath between the door and the B post, although for both to fail simultaneously does seem to be a bit of a coincindence.
I don't myself know of any single point of failure which would affect just the second-row doors. |
Double_R Member Since: 05 Apr 2015 Location: Kent Posts: 6 ![]() ![]() ![]() |
On both sides? Seems a bit of a coincidence...
Thanks, time to get the multimeter out by the sounds of it. |
Are you sure you just didn't notice one wasn't locking for a while? Ray
There is a connector inside the B post very close to the point where the rubber sleeve is fitted. If you are getting the correct lock and unlock energisations there, but the doors aren't locking and unlocking, then it is amost certainly the broken wire problem. It is unlikely that both actuators have failed simultaneously.
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Mine did this so I then re greased all the door hinges with silicone spray grease, and all the latches and mechanisms. Problem solved clearly seized up. Give it q go
