Home > Maintenance & Modifications > Front Wheel Drive Backlash
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Just changed the wheels/tyres over to the Summer set.
While I had a front wheel off the ground, I noticed what I think is a high degree of backlash between the wheel and the propshaft - 22 degrees to be precise (around 165mm on the tyre).
I know it's an old piece of kit but is it a case of "They all do that, Sir, it's a Land Rover" or do I now have something else I need to add to the refurbishment list? Shocked --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #423747 15th May 2015 11:02am
There are many, many components in the front axle which can wear and the cumulative effect can be considerable even when the individual parts are not too bad. If you had one wheel on the ground and are rotating the other you are potentially seeing the cumulate wear in both drive flanges, both CVs, both halfshafts, all the differential gears, and the ring and pinion in the diff.
If it runs OK and without excessive rumbling, knocks and clonks, then to be honest I wouldn't worry.
"They all do that, Sir!"
Post #423760 15th May 2015 12:01pm
shaggydog
As blackwolf says, unless you can hear it grumbling it will go on for years Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #423773 15th May 2015 12:57pm
