Home > Technical > 110 Rear Axle Half Shafts
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
The image below is the rear axle of a 2004 110 I just bought, when switching over the wheels to my surprise it had 1 piece half shafts....
Am I right in thinking that the 2002 on rover axle on the 110 was fitted with 24 spline shafts and Drive flanges !!
Looks suspicious to me Confused
Nidge
Post #423523 14th May 2015 3:53pm
Disco axle, perhaps?
Post #423534 14th May 2015 4:28pm
Nidge
Not sure....I hope not.... to me the Diff looks like the 110 rover type Question
Post #423547 14th May 2015 5:02pm
Devon-Rover
It would need checking of axle numbers but on first impressions that is a TUL Rear axle. Or a Army Wolf 90. Stronger diff but still one piece rear shafts.
A bit of detective work with a wire brush should reveal an axle number.
Post #423574 14th May 2015 6:46pm
TUM would have a P38 diff I think. Not sure about TUL.
Post #423591 14th May 2015 7:25pm
Nidge
Tks Fellas, on further investigation trawling part numbers the shafts seam to be from a early 2004 90 24 spline rear axle
I assume there is no issue running them with the rover axle and diff
Post #423678 15th May 2015 6:27am
As long as the splines fit the diff (which clearly they do), no issues at all.
You won't have the pleasure of replacing the worn-out halfshafts and drive flanges every couple of years that we Puma owners do though!
Post #423726 15th May 2015 8:55am
Fatboy Slim
Wales
I'm sure the one piece shafts will fit puma defenders as well Thumbs Up
Post #425663 22nd May 2015 9:18pm
