Home > Puma (Tdci) > Wet Feet! |
Windscreen seal. If you go through life with your head in the sand....all people will see is an ar5e!!
11th May 2015 4:56pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
k9f is bang on get someone to put your hose pipe on and you sit inside bet you find it its a common thing all the best
11th May 2015 6:46pm |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 83 |
Will it have to come out, or can something be done with it in? Thank Kevin |
11th May 2015 7:00pm |
it can stay in kev just need some liquid rubber and put on seal where leak is im sure one of the guys will tell you a brand to use don't use silicone it rots the rubber
11th May 2015 8:01pm |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
If your corrosion work involved the windscreen 'hinges' and seams as mine did, they'll have removed the windscreen. Refitting the screen (which is likely to have been done by one of the usual 'specialist' firms) is much easier if one of the seal lips is hacked off all the way round. They'll then have tried to make up for this by toshing mastic in places. It will never seal properly though. I found this out when Dave of VGS nee Landyglass took mine out and showed me. I did tell the LR dealer, who hadn't realised what had been done in their name. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
11th May 2015 8:35pm |
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 |
Drivers side could be leaking through bonnet hinge, then dripping in through brake pedal area
Passenger side, again through hinge or just blowing under bonnet then in through nut/bolts that secure the fan Both fittings at the bottom corners of the windscreen to the bulkhead. I removed them both and sealed underneath. The joints between panels under the door rubbers near the joint beneath the windscreen If they sealed the joint under the windscreen without removing the 2 'hinges', probably water is running in there It has leaked on mine in every place that I have mentioned Time consuming to fix, but next to no cost and feels really satisfying when done, till your next leak some where else Dave |
12th May 2015 12:07pm |
