Home > Puma (Tdci) > Wet Feet!
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Wet Feet!
My Defender went for a three week holiday to get some corrosion sorted and sealed up from leaking into the front footwells last summer, before its third birthday and warranty ending.
They seem to have just ran tiger seal between the windscreen frame and bulkhead where the soft gasket it.
What is the likly cause of the leak? (common problem area on tdci) the tiger seal joint, although not ideal, looks ok as a joint and not conducive with how fast the drips are, both footwells.
Any thoughts
Kevin
Post #422698 11th May 2015 4:44pm
K9F
Windscreen seal. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #422701 11th May 2015 4:56pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
k9f is bang on get someone to put your hose pipe on and you sit inside bet you find it its a common thing all the best Thumbs Up
Post #422724 11th May 2015 6:46pm
Kevzeboy
K9F wrote:
Windscreen seal.
Will it have to come out, or can something be done with it in?
Thank
Kevin
Post #422727 11th May 2015 7:00pm
andydef90
it can stay in kev just need some liquid rubber and put on seal where leak is im sure one of the guys will tell you a brand to use don't use silicone it rots the rubber Very Happy
Post #422745 11th May 2015 8:01pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Re: Wet Feet!
Any thoughts
Kevin
If your corrosion work involved the windscreen 'hinges' and seams as mine did, they'll have removed the windscreen.
Refitting the screen (which is likely to have been done by one of the usual 'specialist' firms) is much easier if one of the seal lips is hacked off all the way round.
They'll then have tried to make up for this by toshing mastic in places.
It will never seal properly though.
I found this out when Dave of VGS nee Landyglass took mine out and showed me.
I did tell the LR dealer, who hadn't realised what had been done in their name. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #422755 11th May 2015 8:35pm
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Wet Feet
Drivers side could be leaking through bonnet hinge, then dripping in through brake pedal area
Passenger side, again through hinge or just blowing under bonnet then in through nut/bolts that secure the fan
Both fittings at the bottom corners of the windscreen to the bulkhead. I removed them both and sealed underneath.
The joints between panels under the door rubbers near the joint beneath the windscreen
If they sealed the joint under the windscreen without removing the 2 'hinges', probably water is running in there
It has leaked on mine in every place that I have mentioned
Time consuming to fix, but next to no cost and feels really satisfying when done, till your next leak some where else
Dave
Post #422871 12th May 2015 12:07pm
