Home > Land Rover Customer Relations > Adaptor shaft spline failure between main and transfer boxes
Page 2 of 8 <12345678>
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
It would appear that the diagnosis has already been completed upon many vehicles by a Land Rover approved retailer, mine included and that this has shown a lack of lubrication to the splines is causing the failure. This failure is occurring at a very low mileages to vehicles that are both in and out off warranty.
I think the question being asked is whether Land Rover have a satisfactory engineering cure for the problem or if we as owners are going to have to expect repeated failures over the life of the vehicles.
Post #421587 6th May 2015 2:30pm
YOLO110
Australia
I realise there is a General Election tomorrow... but this is PURE brilliant politics! Thud YOLO... You Only Live Once...
Post #421593 6th May 2015 2:51pm
BykerPete
United Kingdom 2014 Defender 110 300 Tdi CSW Willow Green
Not sure if this helps (might be the wrong bits) and it's probably been mentioned before but . . .
http://www.ashcroft-transmissions.co.uk/mt...t-kit.html
Probably unlikely that JLE will pay for it though Big Cry
Pete.
Post #421599 6th May 2015 3:51pm
Scoobeenut
Byker Pete
Yes the Ashcroft Transmissions part looks like a proper engineering solution and I would have that fitted to my transmission, but JLR have now repaired my output shaft and given a one year parts and labour warranty on the repair.
My dilema and I suspect others too, is will the shaft fail again at some point in the future or do JLR consider that the current fix is suitable for the projected life of the vehicle?
Post #421605 6th May 2015 3:59pm
CRC@LandRover
Verified Account
Verified Account
Hi Scoobeenut
Thank you for your posts.
I note your comments and would advise that should a specific concern be identified by Land Rover, our engineering department will publish a robust fix in relation to the concern in question.
Following a diagnosis of a concern by our retailers, they will effect the relevant fix for the concern in question. However, as I hope you can appreciate we would be unable to realistically predict if a component may or may not fail in the future as our vehicles are complex working machines. For this reason, each repair would be covered by the appropriate warranty depending on the age of the vehicle. (Our parts warranty has recently been increased to two years)
I can also assure you that all records of repairs completed by our retailers are retained and can be referred back to if necessary.
Regards
Ryan
Post #421747 7th May 2015 8:46am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hi Ryan
I don't think this needs the engineering department on this, it just needs a small amount of grease on final assembly!
The photos on this thread, are of one of our work 110s I think that was a 12 plate model?
Over the past few months I have removed and lubricated all of our Land Rover shafts.
We have just taken delivery of another 110 and will be doing the same on that one before it fails!
I have fitted grease nipples on the last 2.
I work on heavy plant and equipment and have always gone with the saying that "grease is cheaper than metal"
I can't believe that this critical part in the Defenders drive train is still being over looked? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #421774 7th May 2015 10:25am
munch90
^^^ yes agree with above
if they greased I think they will last for ages if not forever
Post #421786 7th May 2015 11:39am
Where are the current Defender gearbox/transferbox assemblies actually built and/or assembled?
I imagine that they arrive at Solihull as assembled units, so the grease deficiency has its origins elsewhere.
Post #421790 7th May 2015 11:57am
munch90
guessing the main box and t/fer box are different makes so maybe bolted together at land rover factory
Post #421817 7th May 2015 2:16pm
It seems that the MT82 is built at the Getrag factory in Halewood. Anyone know who/where the transfer box is built, and where the two parts become one?
Post #421823 7th May 2015 2:54pm
Happyoldgit
I shall be watching this thread with interest. Steve.
http://forums.lr4x4.com
Post #421908 7th May 2015 11:28pm
ian series 1
We were at the factory on Wednesday, we saw the engines and gearboxes all as one unit.
So not sure if they arrive like that?
It supprised us as to what was farmed out to other company's regarding the Defender build.
Chassis, roof panels, etc all get shipped in from outside the plant, so would be interesting to know who builds the engine and box up?
I'm dropping the box out of our 5week old 110 next week, will be interesting to see if they are doing any lubrication improvements to the splined coupling? 80" 80" 86" 88" 90"
Post #421918 8th May 2015 6:01am
munch90
^^^^ That well be good to know if there is any change in greasing the joint
also any idea how long ago was the first one you greased , time/mileage etc , be interesting for a look at one thats been greased for a while for wear
i personally think there be fine once greased
my advise to anyone worried adout the shaft is to have box out to grease it before it lets you down and costs you more for parts and also the worry of when it will happen , outside lane of motorway , busy junction
its not a big job and for piece of mind , prevention is better then cure etc , shouldnt cost a fortune , unless you use main dealer
Post #421921 8th May 2015 6:44am
Ryan
Can you share with us what concerns have already been identified and what your engineering department have published in relation to this particular concern?
Post #421938 8th May 2015 8:50am
munch90
supacat
wasn't there a "how to bulletin" that said when fitting new spline parts that they should be greased
think your find that's it , that's there fix
Post #421940 8th May 2015 9:01am
