Home > Puma (Tdci) > No DPF on 2015 Aussie 110
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
Hi there,
I have just read that Aussie Defenders don't come with a DPF. First of is that true, and i so can I purchase the factory Euro one as a simple bolt on? Or is there a plug and play Provent kit for the Defender out there?
Thanks for your help,
Ant.
Post #421534 6th May 2015 10:29am
YOLO110
Australia
Hi Ant!
I don't think they do come with a DPF mate.
I am not certain, but I think the reason is that Australian diesel fuels are not clean or refined enough and with a higher sulphur content to allow them. They do trap particulates...
But if being behind some diesel burners in oz, with clouds of black sooty smoke coming out from the exhausts, I think they would block up very quickly. So I think thats the reason why?
Probably all nonsense however! Laughing YOLO... You Only Live Once...
Post #421589 6th May 2015 2:42pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I suspect they don't because your government hasn't mandated them unlike our Euro masters.
Rather than retro fit one I would spend the cash on some champagne/whatever to celebrate the lack of this troublesome device (1).
Regards
C
(1) lots have had problems with them especially if you tow really heavy stuff or only d very short journeys although my commute is 130 miles each way so mine has never caused any issues 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #421594 6th May 2015 2:55pm
YOLO110
Australia
Yes, thats because they block up with diesel particulates... and then never get hot enough to burn them off.
In Oz, lots of particulates... but also lots of heat! Laughing YOLO... You Only Live Once...
Post #421596 6th May 2015 3:00pm
GypsySamuraiAnt
Perfect, thank you gentlemen. No DPF and some champas it is Mr. Green
Post #421672 6th May 2015 7:38pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
DPF is one of the stupidest pieces ever legislated to be fitted: it reduces soot particles to even finer soot particles which are even more unhealthy. I suspect this blockage in otherwise normal exhaust would mean the engine needs to work harder as well, which means it needs more fuel as well. You are well of not having this piece of sh..., sorry, kit fitted.
Post #421709 6th May 2015 9:19pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Because we are still on EURO 4 standard.
Euro 5 is on the way, I think will be implemented by the end of this year (2015)?
Post #421719 6th May 2015 11:47pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
The dangerous particles result from burning atomized fuel under high pressure i.e. from common rail systems with injectors.
Common rail systems are not fully reasonable for me - especially when thinking about fuel economies - since 109/110 Land Rovers have always consumed 10 liters/100 km
Post #421891 7th May 2015 9:44pm
dgardel
Italy
yes with half HP anf Nm Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #421923 8th May 2015 7:11am
munch90
I think the idea is the finer soot/carbon particles are stored in dpf then burnt again at higher temp to ash which is ment to be less unhealthy than carbon
Post #421924 8th May 2015 7:20am
zone30
In Antwerp a legislation has passed banning all Euro4 without DPF or lower, aged +10 years.
By 2020, anything below Euro5 will be banned.
It concerns around 15000 cars, mostly of low income people.
I know I would targeted as well come 2020, but they are hitting the people who cannot afford a newer car.
Amazing how (high income) politicians cannot empathy with the common man...
All for the wrong reasons as well, I may add. There have been studies that driving oldtimes (+20years) damage the environment less then renewing cars too often.
Post #421986 8th May 2015 10:54am
Jukathy
If you prefer full HP/Nm in a new Defender you'll end up with 15 liters / 100 km or even more Whistle
A Series will not take that much.
Post #422117 8th May 2015 9:06pm
SDV8
2006 Defender 90 Td5 XS CSW Zambezi Silver
It's the same story in London. Only Euro 6 + will be permitted in Cental London from 2020. 2016 Defender Adventure 110
2015 Defender Autobiography 90
2016 Defender V8 Classic Works 90
2020 Defender 110 P400 X
Post #422141 9th May 2015 6:47am
ericvv
Think it is a little bit less stringent as what you say. As of 2016 for diesels is going to be allowed Euro 3 or higher. And as of 2020 it is going to be Euro 4 or higher..... So all Puma's will be ok.
Banning Euro 4 any time soon would be political suicide, revolution.
Here in Switzerland we take a much more pragmatic approach. There always has been an annual exhaust gas test for all cars from 2 years old required, which is entirely independent from the technical inspection. The Swiss have reasoned 2 years ago that all cars diesel and petrol which are Euro 4 or higher are supposedly built to such high emission standards, that the annual exhaust gas check requirement for those just has been canceled. We only consider Euro 3 or lower to be a emission risk, for those the annual check remains in force. Smart move, it means that my Puma won't unnecessarily be revved without load to stupidly high rpm as I know the Belgian controle technique are doing with your cars. Rolling Eyes
Eric
Read here about Antwerp emission decision
http://www.gva.be/cnt/dmf20150508_01670166...ant-zetten You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #422143 9th May 2015 6:56am
