Home > Td5 > OEM stereo single din cage?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Just took out the stereo trying to install the new bezel, then discover all the parts are gone!
retension wires and bolts, the single din cage doesn't seems to be OEM, because it doesn't fit to the bezel...
My question is can I used after market din cage to fit on the OEM bezel?
if not can anyone provide me the part number of that cage?
Thanks Big Cry
Post #421471 6th May 2015 4:30am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #421487 6th May 2015 7:28am
RF3777
OK, I just don't want to give up, took of the whole HU went home and try it out...
using that cage...and I have only one retaining wire, I didn't know the order is per one item!
I installed the wire on the lower part of the bezel, I think the lower take more weight!
carefully remove the whole facia, and unplug some buttons, insert the radio...
I have done it! Mr. Green
Post #421492 6th May 2015 7:53am
JWL
I know it's a bit agricultural but when I put my head unit in mine I put a block of wood towards the back to allow the radio to rest on so it wasn't allways trying to twist the front off. Mine stays in with just the clips on the side I haven't used the wire clips at all and my Defender gets used for everything from the school run to greenlaning and going to pay and play sites and the radio never moves.
Post #421496 6th May 2015 8:17am
