Home > Td5 > 2003 TD5 clutch noise?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Looking for some info to figure out why my TD5 clutch has some squeeze noise every time I release the clutch pedal!!
sounds like "EEEEEEEEEEEEEERR" does it need lube on the spring?
Thanks
Crying or Very sad
Update video add!
https://youtu.be/31WqOclzB-Q
Post #421213 5th May 2015 3:42am
munch90
isn't it caused by the spigot bearing , quite common thing on the td5
Post #421221 5th May 2015 5:40am
RF3777
Where is the spigot bearing about?
how can I fix it?
Thanks Embarassed
Post #421231 5th May 2015 6:06am
munch90
inside the flywheel , sorry not a simple fix
Post #421232 5th May 2015 6:10am
RF3777
Can I just leave it as is?
if this not a serious problem...
Post #421233 5th May 2015 6:12am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Is the noise coming from the pedal inside the footwell or more of a noise from the engine bay?
If it's from the pedal itself, then grease the spring on the pedal (in the footwell)
If that fails, open the engine bay, remove the 6 screws on top of the clutch pedal box, remove the cover plate and give the pivot pin a couple of drops of oil or spray grease. WD40 is too thin and won't last long, plus it'll run down the pedal and end up in the footwell.
Your engine bay might be the opposite way round to mine, but a couple of the screws might be difficult to remove, I bent and kept a screwdriver especially for this job!
It looks like this when the cover's off....
Post #421234 5th May 2015 6:29am
RF3777
Hi, Lambley
The noise sounds more from the footwell, would try to lube the spring first!
Is it possible spray some WD40 through the hole where the pedal come out?
Sorry but where is clutch box located? Mr. Green
Post #421236 5th May 2015 6:43am
munch90
Just read first post again , noisy spring
sorry must have been to bit early for me this morning and said about spigot bearing ! Embarassed Embarassed
Post #421439 5th May 2015 8:43pm
Lambley
It looks like your pedal has had the spring modification done - which makes it easier to press the pedal, mine creaked a bit until I'd greased it, try and grease the spring at the back of the pedal, where it fits into the 2 plastic bits in either side, just put a bit of grease around there and where it touches the back of the pedal and see if it stops squeaking, if not then have a look under the bonnet - above where the pedal sits, there will be a cover with 6 screws, undo them and have a look inside - it should look like the picture posted above, just grease the moving parts of the pedal, try not to get too much grease near the rubber boot that's on the cylinder - just use a spray grease, you'll be fine.
Post #421452 5th May 2015 9:25pm
RF3777
I did some WD40 on it, both the pedal and the clutch box...
the clutch box rubber boot looks torn! Neutral
I did some spry on the rod!
Post #421470 6th May 2015 12:54am
Lambley
And did it work?
If not I'd be tempted to take the spring off the back of the pedal and replace it with an original one, you might have to buy one though, not expensive
Post #421472 6th May 2015 4:36am
RF3777
The noise seems to be down alot, will take a ride later today...
since busy with the stereo bezel... Big Cry
Post #421473 6th May 2015 4:39am
