Home > Maintenance & Modifications > Nakatanenga Antenna?
Page 4 of 4 <1234
VeeTee
Netherlands
RF3777,
Because I did want to feed the new cable through the firewall I cut the cable near the old antenna and put a female connector at the this end. Very easy.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #419092 26th Apr 2015 9:45am
HardCharger
The previous owner changed out the antenna of my D110 to some short (3/4 up the windscreen) antenna for some reason which doesn't seem to do a good job when I try using the FM radio. All stations have static and are not clear. Maybe this Nakatanegna antenna will be the solution I'm looking for.
Just out of curiosity, is there an antenna that will help radio reception but will also work with UHF/VHF applications?
Post #419323 27th Apr 2015 2:26am
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Assuming you want to transmit on VHF/UHF you would need a diplexer/triplexer and a suitable antenna. Usual application is on covert vehicle installs- not a cheap solution.
Steve
Post #421192 4th May 2015 10:16pm
need4speed
leeds wrote:
We get regular consignments from Nakatanenga varying from a single carton to a couple of pallets at a time.
We are at the mercy of couriers but transit time is normally 2-3 days, unless the courier imps decide to misplace a consignment. We have had a delivery stuck in a depot 25 miles away for a week Big Cry
There are lots of new stuff in the pipeline, sometimes they go from design to production smoothly and quickly. Sometimes items are put to 'sleep' then I get my poking stick out and try to jolly things along a bit with mixed results.
Brendan
These in yet Brendan?
Also, does this come with the lead that connects to rear of stereo, or does it connect to existing lead?
Post #421247 5th May 2015 9:09am
K9F
Quick search reveals it comes with a cable length of 133cm. You can use your existing cable as a means of pulling the new one through and just plug it in to your head unit. I fitted an Entreq one ages ago and apparently they seem to be the same item. It comes with a male jack fitted.
http://nakatanenga-tours.de/shop/article_N...TDEF-VA%26 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421250 5th May 2015 9:27am
HardCharger
Steve
Censored .
Thanks Steve, something to think about then.
Post #421257 5th May 2015 10:14am
hoover
Hi anybody in the UK stock this?
I notice their website wont ship to the UK Freelander 2 Flora
200tdi 90 1985 (Not Defender) Rhubarb
Puma 110 5 door Twinkle
Post #939855 28th Jan 2022 2:20pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Post #939857 28th Jan 2022 2:22pm
hoover
Ok thanks, will try an online chat and see if its day weeks or months
Stupid Brexit Freelander 2 Flora
Post #939860 28th Jan 2022 2:32pm
hoover
Ordered and apparently dispatched Very Happy
Splendid! Freelander 2 Flora
Post #939864 28th Jan 2022 3:14pm
hoover
Fair play to 4x4overlander it was on my kitchen table about 12 hours from time of ordering Very Happy Freelander 2 Flora
Post #940337 31st Jan 2022 3:43pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Mine arrived today and was fitted within 24hrs of my conversation with Brendan yesterday Very Happy
I haven't taken it anywhere to test it yet but have tuned FM stations in on the head unit for the first time in 5 or 6 years and found more DAB stations than my cobbled up DAB antenna made from bits of amateur radio equipment.
I suspect that only worked as well as it did because it was bolted to the roof rack which is going (soon hopefully) and hence the need for a good wing antenna.
FM was always an issue even with brand new (cheap) antenna's in the past so this is definitely an improvement so far. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #941962 10th Feb 2022 5:33pm
Page 4 of 4 <1234
