Home > Maintenance & Modifications > Nakatanenga Antenna? |
RF3777,
Because I did want to feed the new cable through the firewall I cut the cable near the old antenna and put a female connector at the this end. Very easy. Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
26th Apr 2015 8:45am |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
Assuming you want to transmit on VHF/UHF you would need a diplexer/triplexer and a suitable antenna. Usual application is on covert vehicle installs- not a cheap solution.
Steve |
4th May 2015 9:16pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
These in yet Brendan? Also, does this come with the lead that connects to rear of stereo, or does it connect to existing lead? |
5th May 2015 8:09am |
Quick search reveals it comes with a cable length of 133cm. You can use your existing cable as a means of pulling the new one through and just plug it in to your head unit. I fitted an Entreq one ages ago and apparently they seem to be the same item. It comes with a male jack fitted.
http://nakatanenga-tours.de/shop/article_N...TDEF-VA%26 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
5th May 2015 8:27am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 744 |
. Thanks Steve, something to think about then. |
5th May 2015 9:14am |
hoover Member Since: 18 Jun 2021 Location: North Wales Posts: 23 |
Hi anybody in the UK stock this?
I notice their website wont ship to the UK Freelander 2 Flora 200tdi 90 1985 (Not Defender) Rhubarb Puma 110 5 door Twinkle |
28th Jan 2022 1:20pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
On back-order here: https://www.4x4overlander.com/product/defender-aerial/
28th Jan 2022 1:22pm |
Ok thanks, will try an online chat and see if its day weeks or months
Stupid Brexit Freelander 2 Flora 200tdi 90 1985 (Not Defender) Rhubarb Puma 110 5 door Twinkle |
28th Jan 2022 1:32pm |
Ordered and apparently dispatched
Splendid! Freelander 2 Flora 200tdi 90 1985 (Not Defender) Rhubarb Puma 110 5 door Twinkle |
28th Jan 2022 2:14pm |
Fair play to 4x4overlander it was on my kitchen table about 12 hours from time of ordering Freelander 2 Flora
31st Jan 2022 2:43pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
Mine arrived today and was fitted within 24hrs of my conversation with Brendan yesterday
I haven't taken it anywhere to test it yet but have tuned FM stations in on the head unit for the first time in 5 or 6 years and found more DAB stations than my cobbled up DAB antenna made from bits of amateur radio equipment. I suspect that only worked as well as it did because it was bolted to the roof rack which is going (soon hopefully) and hence the need for a good wing antenna. FM was always an issue even with brand new (cheap) antenna's in the past so this is definitely an improvement so far. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
10th Feb 2022 4:33pm |
