Home > Puma (Tdci) > Gearshift Hanging RPM |
aage Member Since: 26 Jul 2012 Location: Iceland Posts: 44 |
Recently when shifting gears the RPM takes a few seconds to fall back to normal much longer than usual.
The strange thing is that if I´m at standstill no speed it act normally as far as I can tell. I can step on the throttle and the rpm drops back normally, so this is only when I´m driving that this happen. Does anyone have a clue what might be wrong ? There are no trouble codes I did disconnect the Clutch switch ( the one connected to the clutch pump assembly and nothing changed doing that. BTW my puma has 34.000 km on the clock and has been almost trouble free I would be thankful for any help in this matter. http://www.defender2.net/gallery/index.php?cat=13451 |
2nd May 2015 5:42pm |
bobcat Member Since: 10 Feb 2012 Location: United Kingdom Posts: 12 |
Check brake light fuse and bulbs.
2nd May 2015 8:21pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Check the clutch switch on top of the master cylinder.
2nd May 2015 8:22pm |
Thanks a lot guys.
I think I have already checked the clutch switch. I disconnected it and no change, then I connected btw the two poles on the switch with a wire and no change. I´m gonna check the brake light and bulbs tomorrow morning. It might be that. I have had a water entering the rear brake lights. Yes gonna check that tomorrow morning , the brake lights and fuse. http://www.defender2.net/gallery/index.php?cat=13451 |
2nd May 2015 11:06pm |
Roz Dev Member Since: 09 Dec 2014 Location: East Coast Posts: 72 |
Mines doing it too, asked the same question in the technical forum last week, here's the reply
http://www.defender2.net/forum/topic22317....ev+holding |
3rd May 2015 1:00am |
You where right . The brake light plug was rusted and shorted, the fuse blown. Tomorrow I´m gonna buy new brakelight plug.
Thanks a lot guys , you saved me a lot of work (I would probably never have figured this out by myself) . http://www.defender2.net/gallery/index.php?cat=13451 |
3rd May 2015 11:18pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1642 |
My 2.2 has done this from new... Don't they all do this? YOLO... You Only Live Once... |
4th May 2015 6:03am |
New brakelight plug and fuse. Drives like brand new again . http://www.defender2.net/gallery/index.php?cat=13451
4th May 2015 6:36pm |
it's only a feature in the 2.2, it's a fault in the 2.4. |
5th May 2015 11:49am |
Ok!
Do you happen to know why is the a 'feature'? It's actually a PITA! YOLO... You Only Live Once... |
5th May 2015 12:25pm |
