![]() | Home > Puma (Tdci) > EGR tip |
Forestman1 Member Since: 16 Apr 2015 Location: Sverige Posts: 13 ![]() ![]() ![]() |
Great
There is 'limited' success with buying a single blank off E-bay. Two failures in the following thread....
http://www.defender2.net/forum/topic32966....=egr+blank Buy one and use it as a template and get 6 made with the following sizes....18mm, 16mm, 14mm, 12mm, 10mm and 8mm. Start with the 18, run with that for a few days then work your way downwards. ![]() Treat every day as if it is your last....one day you will be right!! |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
Mine does this for nearly 4 years always , never bothered me . Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
