Home > Puma (Tdci) > EGR tip
Page 3 of 3 <123
munch90
Post #421071 4th May 2015 2:28pm
Forestman1
Sweden 2011 Defender 110 Puma 2.4 SW Galway Green
Great Razz Defender 110 SW S, 2011, Galway Green
Post #421076 4th May 2015 3:09pm
K9F
There is 'limited' success with buying a single blank off E-bay. Two failures in the following thread....
http://www.defender2.net/forum/topic32966....=egr+blank
Buy one and use it as a template and get 6 made with the following sizes....18mm, 16mm, 14mm, 12mm, 10mm and 8mm. Start with the 18, run with that for a few days then work your way downwards.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421077 4th May 2015 3:24pm
munch90
Could start with small hole like the one off ebay then if light comes on , file or drill hole larger and try again , at least its got slotted holes so fitting is easy
Post #421079 4th May 2015 3:46pm
K9F
Post #421080 4th May 2015 3:51pm
Alexke
Belgium
Mine does this for nearly 4 years always , never bothered me . Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #421285 5th May 2015 11:59am
Page 3 of 3 <123
