Home > Td5 > Help! Hazards, no indicators 53 plate 110
bifterx
United Kingdom 2004 Defender 110 Td5 DCPU Oslo Blue
Hi
My indicators have stopped working. Hazards are fine and also flash on alarm set/unset is fine.
Fuse in centre box is fine. I replaced flasher unit just in case.
Any thoughts?
Thanks
Rob Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭
Freelander 2 SE manual
Defender 110 TD5 DC
Post #420677 2nd May 2015 4:05pm
K9F
Column switch. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420679 2nd May 2015 4:10pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
You probably need to get a new stalk, easy enough to replace....
http://www.ebay.co.uk/itm/DEFENDER-INDICAT...234ee34814
Post #420693 2nd May 2015 4:56pm
bifterx
Reckon? I'll give it a go. Done forums suggest hazard switch but as it operates ok, I'd sort of discounted it.
Defender 110 TD5 DC
Post #420707 2nd May 2015 5:22pm
bifterx
Big Cry tried new column switch. No cigar. Any other thoughts? Thanks rob Disco 300TDi XS - Gone
Defender 110 TD5 DC
Post #424008 16th May 2015 12:12pm
