![]() | Home > Puma (Tdci) > Centre Console removal |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1333 ![]() ![]() ![]() |
From memory, with the torx head screws removed, I think I just slid an old plastic credit card between the edge of the centre console and the panel it pushes into. Started at the bottom and gently eased each side out a bit at a time till it could easily be pulled off.
I'm sure someone else will be along shortly with other tips. |
More pressure, if you've a trim removal tool or a wallpaper scraper try to spread the load and prise evenly.
From the following threads and experience the two torx screws and it'll shift. ![]() http://www.defender2.net/forum/topic30969....tre+fascia http://www.defender2.net/forum/topic10556....er+console http://www.defender2.net/forum/topic824.ht...er+console http://www.defender2.net/forum/topic3079.h...er+console If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
