Home > Puma (Tdci) > Lurch from front to rear to front axles when selecting 2nd
mountaingoat
Hi All,
Brand new XS 110 - has happened a couple of times within first 35 miles on road: when in forward travel and selecting 2nd gear the vehicle abruptly lurched forwards and rearwards uncontrollably (back and forth). I immediately re-engaged the clutch to take it out of 2nd gear. I�m certainly not unused to driving defenders/land rovers albeit more so without anti stall on and off road. I�ve come to the conclusion that I may have inadvertently left my foot slightly pressed on the clutch when engaging into 2nd� and / or the anti-stall is misreading the selection� human error or a known issue?
MG
Post #420145 30th Apr 2015 12:02pm
K9F
Known and well documented issue with plenty of information.....
Do a forum search under 'rev hang, judders or kangaroo.' Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420156 30th Apr 2015 12:55pm
mountaingoat
Thank you K9F - very helpful and I'm breathing again. Thumbs Up
Post #420170 30th Apr 2015 1:28pm
K9F
Very Welcome....
Had to resist the urge to type the "They all do that Sir!" But succumbed to it in the end, hence this post. Laughing
In mitigation maybe not all.....but common enough. With a slight change in driving style (as difficult as that may be the older you get) you will get used to it I am sure. Enjoy it and welcome to the madhouse.
Post #420171 30th Apr 2015 1:32pm
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Takes a few weeks but you seem to get into 3rd gear a lot quicker , I find a very relaxed style of driving seems to cure it, rather then the balls out method I started with !
Post #420174 30th Apr 2015 1:44pm
