Home > Puma (Tdci) > Lurch from front to rear to front axles when selecting 2nd |
Known and well documented issue with plenty of information.....
Do a forum search under 'rev hang, judders or kangaroo.' If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Apr 2015 11:55am |
mountaingoat Member Since: 16 Jan 2015 Location: London Posts: 4 |
Thank you K9F - very helpful and I'm breathing again.
30th Apr 2015 12:28pm |
Very Welcome....
Had to resist the urge to type the "They all do that Sir!" But succumbed to it in the end, hence this post. In mitigation maybe not all.....but common enough. With a slight change in driving style (as difficult as that may be the older you get) you will get used to it I am sure. Enjoy it and welcome to the madhouse. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Apr 2015 12:32pm |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 |
Takes a few weeks but you seem to get into 3rd gear a lot quicker , I find a very relaxed style of driving seems to cure it, rather then the balls out method I started with !
30th Apr 2015 12:44pm |
