Home > Wheels & Tyres > Storing tyres |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
30th Apr 2015 1:52am |
Flyingfocrs Member Since: 12 Jan 2015 Location: Deepest darkest Aberdeenshire Posts: 155 |
I have a set of storage trees that pile the wheels and tyres up but keep them seperated, this means you don't have to keep restacking them all the time.
I picked up some cheap sets but while they do the job aren't the best quality and could do with having a wider more stable base. They are fine for my wheel only spares but the set with tyres on are a bit wobbly and I have them tied back to a wall. Stored in a cool dark area they also came with a cover that slips over the top to stop UV damage. But as I don't intend to reuse the tyres that are on the wheels i'm not that bothered as i only got them with the alloys. |
30th Apr 2015 2:20am |
I used tyre bags, and laid them in a row under the 110
If you stack them, best no more than 2 high as they can go off balance You can get scaffold poles and make a vertical stack Keep them out of direct sunlight Not sure if more/same/less pressure .. I left mine the same HTH |
30th Apr 2015 6:20am |
