Home > Puma (Tdci) > 7000 miles - air filter |
Supacat.....Could a contributing factor that your filter appears to have started to detach be down to the air box modification where the water seperator has been removed? If you go through life with your head in the sand....all people will see is an ar5e!!
27th Apr 2015 3:47pm |
don't think supacat has done the airbox mod
27th Apr 2015 3:52pm |
Am I reading this wrong or is he in the process?.....Apologies if I have.
http://www.defender2.net/forum/topic36599-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 27th Apr 2015 4:01pm. Edited 1 time in total |
27th Apr 2015 3:58pm |
They are indeed but due to his comment about restriction I assumed he'd done it and they were old pictures perhaps?
2 + 2 made 5....... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Apr 2015 4:03pm |
ah I see , no think there pics of it now
27th Apr 2015 4:05pm |
My mistake. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Apr 2015 4:06pm |
Apologies for any confusion - I still have the cyclone in place and have no plans to remove it based on the empirical evidence when doing the washing up at home
Fill an empty beer bottle with water, tip upside down and count the time it takes to empty; then do the same again but this time give the bottle a brief swirl when upside down. The latter empties the bottle that much faster. QED I don't think it's a restriction; or rather it's not a limiting factor on the amount of air the engine can breathe. |
27th Apr 2015 4:57pm |
I'm with you on this. I haven't embodied it and don't intend doing so at this juncture. If you go through life with your head in the sand....all people will see is an ar5e!!
27th Apr 2015 5:51pm |
I personally dont think the gains are enough to really worry about , 11nm thats about the same as pushing the defender with the tip of your little finger !
Any extra air the engine can get by modding will only show under hard throttle and i dont drive like that . |
27th Apr 2015 5:57pm |
