![]() | Home > Maintenance & Modifications > Door hinge recommendations please! |
Blackwolf I have a set of stornoway grey take offs from my 90 you can have for free to do with what you want. PM if interested and we can arrange pick up. Think they may tick all your boxes, OEM, right colour and don't get any cheaper. You will still obviously need to source rears.
![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
Why would stainless be do bad? I know of galvanic corrosion but if they were painted all over that'd isolate them and if a specific corrosion inhibitor for use with stainless like the Naka stainless bolt kit grease has I can't see the problem.
I think if I remember correctly parts are rubber shimmed anyway or at least hinge to body. Etch primer would give a good 'bite' into stainless so that wouldn't be a problem to paint. I suppose the price is high though which may be the factor? ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17715 ![]() ![]() ![]() |
@K9F, PM sent, you are indeed a gentleman!
![]() @C90Steve, they're not bad, I just don't want them! (Not particularly relevant to hinges, but having over the years spent many, many hours removing (or attempting to remove) the unnecessary A2 csk socket-head cap stainless fasteners* from my Patriot rack, most of which time has been spent cursing and bleeding in similar amounts, I have a general aversion to using stainless fittings and fasteners when they are unnecessary. Those of you who know me will know that my Def works and plays hard and is not polished and prettied. For me there is no advantage at all in stainless)! Never, ever, use a countersunk A2 hex socket head setscrew in a hole tapped into aluminium if you think you might ever want to remove it! |
NOW SOLD!.......
