Home > Maintenance & Modifications > Electronic rust prevention
grafty99
Has anyone heard of this before? Not sure if it you work, seems a bit dubious to me Confused
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #418898 25th Apr 2015 10:50am
munch90
heard about such things , but never seen one or heard anyone whos tried one
Post #418899 25th Apr 2015 10:54am
grafty99
I suppose it makes sense, they changed from positive earth vehicles because of accelerated rust if I'm not mistaken? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418903 25th Apr 2015 11:15am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
Boats use something like this but I'm confused. Why would they apply a "frequency" when they want to make the car body negative? That implies an alternating voltage when it seems to me they need DC.
Anyway, with half a Landy being aluminium and maybe or maybe not very well joined electrically to the chassis, I think this is best kept down under.
Post #418904 25th Apr 2015 11:16am
grafty99
According to the video, it ranges between 200-400 volts, this I assume, is easier and less power hungry to achieve with ac rather than dc? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418905 25th Apr 2015 11:21am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Sounds like rubbish to me. Avoid. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #418912 25th Apr 2015 12:08pm
JWL
Be a good start to theft prevention Whistle Perhaps up it to 1000V
Post #418917 25th Apr 2015 12:27pm
grafty99
Well they put sacrificial anodes on boats so perhaps something like that would work?
And no, the bodywork shouldn't be a sacrificial anode Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418918 25th Apr 2015 12:34pm
K9F
I work in the marine industry and whilst sacrificial anodes and galvanic isolators are very, very effective of reducing (not preventing) corrosion I can see perhaps a slight flaw when it comes to Defender application as did Nevillerover. A boat sits in water which is a perfect earth and conductor. The Defender is manufactured from different materials which quite often can be difficult to find an earth at the same potential as the battery earth. With the application/fitment olf this gismo should the entire vehicle not be at the desired potential will the panels/areas not at that potential possibly be subjected to increased corrosion as a result? All pie in the sky and speculative I know.
Ultimately all any corrosive process needs is two different potentials, moisture and oxygen. Using the correct fasteners, isolating 'bolt ons' with gasket or wet assembly with a decent sealant and of course waxoyl or Dinitrol to prevent oxidisation is still the most proven and effective method along with regular monitoring for any deterioration. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #418932 25th Apr 2015 3:06pm
gilarion
I have just had my narrow boat hull blacked with Two Pack Epoxy, while it was in dry dock I asked about the anodes and what they were for and got the same answer as you gave K9F. Although through interest I looked them up on the internet and got this good description.
If two metals are in a conducting liquid, i.e. water, and connected together a current will flow between them. This is how a battery works. As water is a poor conductor the current will be very small, but as it is there 24 hours a day, 7 days a week the cumulative effect can be significant. On a boat with brass skin fittings, a brass propeller and even slightly different grades of steel can all effectively become the plates of a battery and as metal will be removed from one side by going into solution to release the electrons, corrosion will occur. This is the dreaded “galvanic corrosion” that gives rise to pitting.
I did not have to have them replaced on my boat as the condition of them was good. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #418956 25th Apr 2015 5:15pm
K9F
Question Question
Really??? Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #418980 25th Apr 2015 7:03pm
Eduardo
Yep, Gilarion is rigth
Water itself is considered non conductive (do the test with deionized water).
But if you put salt in it is another history.
More salty more conductive. So you have more possibility to conduct electricity in sea water than in a tap water.
Ultra pure water can have 5.5 · 10-6 S/m
Tap water have 0.005 – 0.05 S/m
and Sea water have 5 S/m
Anyway those values are not too much compared with the cooper with 5.96×10+7 S/m
But on the other side is more than rubber 1x 10−14 S/m and teflon 1 x 10-23 S/m
Cheers Eduardo
Post #419025 25th Apr 2015 9:32pm
K9F
That'll be salt water then....... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419046 26th Apr 2015 12:25am
Eduardo
Yep K9F, but the point is not the water itself is the salt that contains Thumbs Up
For this reason cars used near the sea and when salt is used in the roads are more propensive to rust than the ones used inlands in more warmer climates.
Cheers Eduardo
Post #419051 26th Apr 2015 4:30am
Buccaneer
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I have used vehicles that pass a current through them on a perm basis to indicate whether something has been attached to the vehicle. Anything that is attached disrupts the field on the car and flashes up something has been attached. The Rules:-
1 Buccaneer comes back alive.
2 Chicks dig scars.
GB260
Post #419053 26th Apr 2015 5:45am
