Home > Maintenance & Modifications > Induction pipe modification on a Td5 anyone?
Page 1 of 3 123>
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've done pretty much most things to my Td5 90 and love it, but after spending some time looking at the intake from the wing to the airbox, it looks a bit restrictive with all the joins and bend, is this the case, does it matter, and is there a way of simply having a hose from the wing to the airbox with less restrictions?
Does anyone make a hose or kit to replace it?
Post #418879 25th Apr 2015 8:20am
grafty99
Irb did mine, 5.5 inch pipe (I think) from the box to the wing. Without the grille on you can fit your arm down it! Sounds lovely too, especially with a vnt Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #418888 25th Apr 2015 9:10am
grafty99
You can see the pipe running in front of the brake servo here
1990 Vogue SE
Post #418890 25th Apr 2015 9:14am
Lambley
Thanks Grafty, looks like just what I'm after.
Do they sell the parts to do it?
Post #418892 25th Apr 2015 9:28am
grafty99
I'm not sure, mine was done as a prototype for the kit. I'll get in touch with Ian and pm you Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418895 25th Apr 2015 9:48am
Lambley
Cheers Grafty, much appreciated Thumbs Up
Post #418897 25th Apr 2015 9:49am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
I did mine myself. Never seen the IRB kit, but funny how similar it is :p!
Post #418919 25th Apr 2015 12:04pm
Lambley
Thanks Taaz,
Looks like you've done the whole shabang and done the VNT turbo too, I don't want to go too far, just the intake to the airbox would be great. What size pipe did you use please? I guess you made something up for the wing intake?
Post #418920 25th Apr 2015 12:09pm
excossack
Did you notice any difference in performance with the 5.5" pipe ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #418921 25th Apr 2015 12:22pm
taazzukcb
If you bare with me, I will take some closer pics later and get some of how it goes into the air box etc and try and do a list of bits and bobs!
I thought I had some pics but just looked through me phone and seems I never did!
Post #418923 25th Apr 2015 12:28pm
taazzukcb
I cant comment about the difference to a stock motor as it was all done at the same time as the rest of the bits went on.
However even with just a remap, the stock piping is massively restrictive and will be quite limiting, so larger bore would allow more air at a quicker rate giving a much better map and the engine wont be left wanting for air.
I believe the optimal feed is 102mm (4") straight through. 76mm would give much better flow to, but if you want the most out of it, 102mm is considered the minimum!
Gives a ruddy nice noise to :p!
Post #418924 25th Apr 2015 12:32pm
Lambley
Brill, thanks Taaz, I've just been and taken off the air-box and piping, the entry to the airbox funnel is 76mm, so a 76mm pipe to there from the wing intake would help, and not be too difficult by the looks of things, otherwise it'd mean making a plate or something to fix the pipe to.
I'll wait to see the pics later
Post #418927 25th Apr 2015 1:02pm
grafty99
I did notice a big difference with the larger pipe, much quicker to come on boost and pulled harder at the top end. I had the inwards pipe and air box mod at the same time Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418949 25th Apr 2015 3:53pm
grafty99
I also had a vnt, but did the air box mods before the turbo change Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #418950 25th Apr 2015 3:54pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
taazzukcb, where did you get the Silcone hoses from,one for the the turbo to air intake, second one by the MAF meter, would really appreciate the info, I also have a VNT turbo. Thanks.
Post #418976 25th Apr 2015 5:47pm
Page 1 of 3 123>
