Home > Maintenance & Modifications > Induction pipe modification on a Td5 anyone?
Page 3 of 3 <123
K9F
Details of the Provent fit here. I had quite a conundrum as room was tight mine being an XS.
http://www.defender2.net/forum/topic26798....p;start=60 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419500 27th Apr 2015 4:40pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
It vents out through a mini filter.
(This was supposed the be the right way up! Sorry!)
Post #419508 27th Apr 2015 4:58pm
ibexman
Cheers Thumbs Up
Post #419509 27th Apr 2015 5:00pm
rustandoil
Any further developments on this induction pipe mod? thinking about doing similar to my TD5 but its very tight with ABS and i would like to keep the standard radio aerial Whistle
Pictures would be a great help Thumbs Up
Had a look on the IRB website and cant see any links to a "kit"
Post #448699 24th Aug 2015 1:46pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Hi Eddie,
I did mine with a 76mm silicone pipe and a home made inlet - bought from ebay. It certainly helps with breathing but I can't say there's a performance gain. Sounds nicer though!
These aren't the best pictures but it'll give you the idea.
I used the original inlet and cut a hole in it, then fitted the new metal inlet that allows the larger pipe to be fixed, then removed all the existing plastic pipework, the 76mm fits directly to the air filter housing, it also fits under the master cylinder nicely and no need to move the aerial, I put some filter sponge on the outlet to stop any leaves/dust etc from being sucked in but allowing moisture to run through ..... I hope this helps
Post #448768 24th Aug 2015 5:25pm
rustandoil
I know it's a bit of thread resurrection, but it seems I haven't thanked Lambley for posting those very informative pictures Thumbs Up
I still haven't done anything regarding this modification on my own TD5 Big Cry
Post #559561 28th Aug 2016 4:59pm
Yorkshire90
This topic seems to be doing the rounds on facebook too.
My TD5 is running a strong IRB Stage 2 package. However, I fitted a Mantec snorkle when I first got it. I think I need to do something about it tbh... "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much*
IRB Developments rebuild: Project Ice cube 2012-......
http://www.defender2.net/forum/topic11056.html
Post #563738 13th Sep 2016 8:27pm
Page 3 of 3 <123
