Home > Puma (Tdci) > oil pressure sensor size - info needed
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
I'm interestred to replace the standard oil pressure sensor with another dual sender that can drive a pressure gauge and close a switch when the pressure fall below 0.5 bar.
The specs of the LR004410 show that the connector is 1/4 18 NPT.
I would like to know if someone of you could confirm the size and if is conical or not.
Thanking in advance for any help.
Post #278733 2nd Nov 2013 8:10am
Good job I checked mine today - it looks a little wet Shocked
Post #418124 22nd Apr 2015 8:59am
