oil pressure sensor size - info needed
I'm interestred to replace the standard oil pressure sensor with another dual sender that can drive a pressure gauge and close a switch when the pressure fall below 0.5 bar.
The specs of the LR004410 show that the connector is 1/4 18 NPT.
I would like to know if someone of you could confirm the size and if is conical or not.
Thanking in advance for any help.
2nd Nov 2013 8:10am
Good job I checked mine today - it looks a little wet
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
