Home > Puma (Tdci) > Rear aux power socket for dash cam |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
If you mean the purple wire behind speaker panel [often used for aux power supply] then It's a permanent live feed, not switched. Guns and Landrovers .... anything else is irrelevant.
21st Apr 2015 10:27am |
General Grabber Member Since: 27 Dec 2013 Location: Mos Eisley Posts: 49 |
Thanks Dave,
Yes that's the one. I've done the mod, but just couldn't remember if it was permanently live or not. |
21st Apr 2015 10:29am |
If it is only ignition live will the camera record any parking prangs whilst you are away from the vehicle?
21st Apr 2015 12:37pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8133 |
Does anyone know which fuse this supply runs off? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Sep 2015 6:44pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
Hi there, 20A fuse of the towing socket under drivers seat.
3rd Sep 2015 6:58pm |
cheers, is there only one 20A in there? Cheers
3rd Sep 2015 7:01pm |
You could always put a little split charge relay in there to make it only come on when the engine is running.
I've been mulling over putting a small battery back there in the lights box to run lights and charge phones from. |
4th Sep 2015 11:46am |
ok, so where is this 20A fuse, only have 15 and 30 in there. in the little box that is or is it somewhere else? Cheers
10th Sep 2015 1:45pm |
now sorted, thank you for pic HairySteve
i had confusuion over the fact that mine had a 15A fuse in there! typical LR! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Sep 2015 6:19pm |
