Home > Puma (Tdci) > Rear aux power socket for dash cam
General Grabber
Morning all,
Can anyone tell me if the aux power socket modification for the rear of a Defender (2.4 / 90 / MY2010) is a permanent live or is it switched with the ignition?
Am thinking about running a dash cam in the rear and plan to use the rear aux socket to power it but would like it to be switched with the ignition.
Thanks all.
Post #417878 21st Apr 2015 10:04am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
If you mean the purple wire behind speaker panel [often used for aux power supply] then It's a permanent live feed, not switched. Guns and Landrovers .... anything else is irrelevant.
Post #417881 21st Apr 2015 10:27am
General Grabber
Thanks Dave,
Yes that's the one. I've done the mod, but just couldn't remember if it was permanently live or not.
Post #417882 21st Apr 2015 10:29am
If it is only ignition live will the camera record any parking prangs whilst you are away from the vehicle?
Post #417910 21st Apr 2015 12:37pm
jst
Does anyone know which fuse this supply runs off? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #451915 3rd Sep 2015 6:44pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Hi there, 20A fuse of the towing socket under drivers seat.
Post #451925 3rd Sep 2015 6:58pm
jst
cheers, is there only one 20A in there? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #451926 3rd Sep 2015 7:01pm
Cupboard
You could always put a little split charge relay in there to make it only come on when the engine is running.
I've been mulling over putting a small battery back there in the lights box to run lights and charge phones from.
Post #452159 4th Sep 2015 11:46am
jst
ok, so where is this 20A fuse, only have 15 and 30 in there. in the little box that is or is it somewhere else? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #453935 10th Sep 2015 1:45pm
jst
now sorted, thank you for pic HairySteve
i had confusuion over the fact that mine had a 15A fuse in there! typical LR! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #453978 10th Sep 2015 6:19pm
