Home > Maintenance & Modifications > Dual Battery Install - job now finished
Page 2 of 3 <123>
Venomator
jonnyboy wrote:
So finally got another weekend to finish the job
First job was to trim the fuse box support as the it was too close to the +ve battery terminal. I'd already trimmed the bolt after it caught on the metal holder on first installation - that was a shock...
Job's a good 'un - well, need the stickers on the fuse box....
Job is, indeed, a good 'un Jonny and one to be very pleased and proud of I'd say... Bow down
You could've simply turned the bolt around, rather than trimming it, no?... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #417617 20th Apr 2015 3:22pm
Sorry not making myself very clear.
Is there any advantage to having the wingnut arrangement & a clinch bolt vs just a clinch bolt clamp with the cable running directly in and being crimped / soldered /screwed?
Post #417618 20th Apr 2015 3:23pm
jonnyboy
United Kingdom 2005 Defender 90 Td5 XS CSW Tonga Green
Venomator - you're right, but then the square head of the bolt wouldn't be sat in its proper recess and that would have troubled my OCD.... Whistle It would still have been tight and there was 15mm available to be trimmed
Supacat - you're right, I could have done that but the kit came supplied as is and didnt really want to buy more bits.
Post #417619 20th Apr 2015 3:31pm
OK, I was just wondering if there was a cunning disconnection plan for an alternative use...
Post #417645 20th Apr 2015 5:16pm
ChrisJ
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Fantastic write up! Thanks for taking the time to detail it for us.
I do love good tech topics like this.
Thumbs Up
Post #417756 20th Apr 2015 9:39pm
dgardel
Italy
Uh!
you have the steering wheel on the wrong side............. Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #417874 21st Apr 2015 10:27am
g-mack
Jonny how did you attach accessories to batt box? rivnuts? My 109 thread
my youtube channel
Post #473419 17th Nov 2015 11:10am
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Any chance you could provide a "parts list" and where you got all the bits from - this is on my list of things to do as well 2013 Aintree Green 110 Station Wagon SX
Post #473446 17th Nov 2015 12:36pm
g-mack
i think he bought it in kit form from Tim @ the mobilecenter. My 109 thread
my youtube channel
Post #473458 17th Nov 2015 1:43pm
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
Hi jonnyboy, What is the first anderson connector going to be used for? And why is the wiring so much thicker?
If you were at a camp site or at home would you charge the batteries using one of these anderson connectors?
I'm in the process of buying the same kit from Mobile Center, so will be following your photos soon.
Richard
Post #473501 17th Nov 2015 3:11pm
jonnyboy
Just spotted some more replies on this old thread of mine. Oops
G-mack - nuts and bolts. Used my 7 year old to go underneath the car and hold the spanner Thumbs Up
Warden - yes they came from the MobileCentre. They have the full kit you can buy as I too wouldn't have had a clue where to start on putting the parts list together. Having the kit and following a few threads on here got me sorted. And Tim there was more than helpful in my planning
Rleslie - the yellow connector, for me, is for jump starting and running a car trailer winch. Made up some jump leads (you can buy them from MC) as its pretty difficult to get on both battery terminals when in this configuration
Post #504488 14th Feb 2016 9:35am
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Fantastic job jonnyboy, I love well designed and installed electrics and what you have done looks great. Its now given me more ideas for what I'm going to do with the 90 and more than likely going to result in more boxes of bits awaiting time to fit. 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #504509 14th Feb 2016 10:54am
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Inspired by (a) Having a flat battery in the cold and (b) this great write up. In particular the 'back of a fag packet' wiring diagram, which makes life so easy to follow... I have installed pretty much the exact same system, minus the additional fuse box and a few Bus bars. The Blue Sea system being mounted against the rear of the seat box. Here is my effort :
A question on the operation, to check I've not messed something up. All seems good, Switch module LED's light up while driving to show connectivity of the two batteries, due to voltage level.
What seems odd is it stays on even after i turn the ignition off, meaning they are still joined. Logically i guess they should be as the batteries are very new and holding good charge.
But it seems odd to me tat it wouldn't disconnect. Why have the LEDs slowly discharging two good batteries at this point, until they go below X volts.
Does your switch LED's remain on after ignition is turned off ?
Post #504913 15th Feb 2016 5:25pm
jonnyboy
Thanks for the note Consumerize. I take offence at the "fag packet" remark. It was actually a napkin.... Wink
That doesn't sound right re the LED. Have you got the switch on the Relay set to Remote? You should hear a "thunk" as it switches on soon after starting the car and then a similar "thunk" of it disconnecting soon after turning the ignition off.
My LED only comes on when I come off Auto to connect the batteries
John
Post #508768 27th Feb 2016 7:18pm
consumerize
Thanks John,
As you say when i get in, start the engine and drive off. There is the tell tale 'Thunk' of the Blue Sea relay. At this point my Switch is then Illuminated Red.
Switch on relay is set to remote.
When i pull up to stop, it remains illuminated Red and stays that way, for some time. hours it seems. when i come back maybe at the end of the day, the switch LED's are turned off again. Im assuming there has been a 'Thunk' in my absence, because it does it again when i drive off once more.
So from what you say, yours never lights up unless you manually click the switch to join the batteries ?
Glyn
Post #508800 27th Feb 2016 8:27pm
Page 2 of 3 <123>
