Home > Puma (Tdci) > Anderson connector fitting
tobz102
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I've fitted an Anderson connector to the seat box of my Puma to allow for easy, quick jump starting of the horse lorry that is constantly flat Laughing
I so far haven't wired it to the battery, I intend to wire straight onto the +ve and -ve terminals. The positive is no problem due to the bolt attached to the terminal allowing connection. There is no equivalent bolt on the negative, has anyone got a solution to this? Also, is it advisable for me to fit an isolator or somehow fuse the feed to the connector. If yes, does anyone have a link to a suitable switch/fuse solution?
Toby
Post #416871 17th Apr 2015 3:40pm
K9F
Simplest solution is take the supply off your 100 amp megafuse then stick a 30/40/60 amp in-line to your Anderson positive dependant on what you intend using it for. If those ratings aren't enough just rely on 'diversity' and the mega fuse. Do you know what the craking amperage is when jumpstarting?
http://www.halfords.com/technology/car-aud...6755&_
http://www.halfords.com/technology/car-aud...der-sn2-30 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #416874 17th Apr 2015 3:48pm
munch90
cut the terminal off and fit a different type
something like this
eBay item number:
eBay Item No. 381219697837
just need to get a heavy duty ring tag crimped on to cable
you could fuse it , but would need to be 400-500a mega fuse
something like this
eBay item number:
eBay Item No. 111105946492
Post #416875 17th Apr 2015 3:49pm
munch90
think he will need something bit heavier than that for jump starting a horse box lorry
tobz102 what size/amp rating Anderson connector have you fitted?
Post #416877 17th Apr 2015 3:53pm
K9F
Realised that hence the edit..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #416878 17th Apr 2015 3:54pm
munch90
k9f that link is for 30amp fuse ?
personally I would a lot heavier like min 300amp for jump starting
ah ok sorry k9f , just read your edit about megafuse Embarassed
Post #416882 17th Apr 2015 4:00pm
tobz102
The horse box is only on a 3.5ton van chassis it's not a lorry as such.
I've fitted 175A durite connector..
Post #416888 17th Apr 2015 4:21pm
munch90
the 175a seem to be the most common used for jump leads
Post #416894 17th Apr 2015 4:39pm
