Home > Puma (Tdci) > Heating in the footwell
Def Junkie
Hi, last weekend I was driving out of town and flooring it quite a bit and the driver side footwell (around the hand brake and small 4wd shift lever) started emanating a considerable amount of heat. The temperature gauge stayed normal through out. This lasted the whole way through but on the return trip also flooring it quite a bit there was no noticeable heat that was emanating. Anyone here got any advice? Could it be the clutch? I've been told that some of the rattles when starting and turning off the engine that I am getting are the early signs of needing a clutch replacement. Mine is a MY 2009.
Post #416300 15th Apr 2015 5:24am
LR90XS2011
there a couple of threads on here about this, it appears a dragging hand brake can cause it , easy to check as it would be very hot after a run, however it happens with no defects due to heat from the exhaust, mine has improved since removing the centre silencer and replacing it with a straight through pipe. Clutches generally start to fail with a rattle and there is no reports of extra heat, to create a lot of heat it would need to be slipping again there are threads on here about clutchs DEFENDER 90 TDCI XS,
Post #416302 15th Apr 2015 6:14am
landy andy
It won't be the clutch, and heat in that area is quite normal. Benith that area you have the exhaust, and just infront the cat and turbo. I doubt you have anything to worry about, but it certainly won't be the clutch.
Andy
Post #416303 15th Apr 2015 6:16am
Def Junkie
Many thanks guys. Very much appreciated.
Post #416344 15th Apr 2015 10:16am
TJ101
Bet you had the window open ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #416351 15th Apr 2015 10:49am
Def Junkie
Yes I did, and had the AC on during the return trip when I didn't feel the heating in the foot well. But what has having the windows open got to do with this? Confused Shocked
Post #416358 15th Apr 2015 11:16am
Naks
open window = heat sucked through the gearbox area into the cabin.
that is why the original Defender had those windscreen flaps - with these open, it would create a high pressure zone in the cabin and the cabin would stay cool. --
Post #416370 15th Apr 2015 11:57am
Def Junkie
Bow down Bow down
Post #416372 15th Apr 2015 12:14pm
TJ101
Naks beat me to it,, an open window suck's the heat up from the seat box, had the same on all past Puma's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #416385 15th Apr 2015 1:15pm
Def Junkie
Tks TJ. Glad to know there is nothing technically wrong. Bow down
Probably should be starting a new thread but how do I know it is time for a new clutch. Presently I get a clunky rattle when I start and switch off the engine. Have been told that the death of the clutch on a Puma would be sudden and it won't go thru the slipping phase. Don't want to get stranded but also don't want to go for a replacement unless I absolutely have to.
Post #416423 15th Apr 2015 4:18pm
TJ101
Only had to change 2 clutches on Puma's Both 90's both early ones 07/08 models
Both just rattled on tickover, never slipped, just the plate springs rattling California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #416424 15th Apr 2015 4:25pm
In my experience a Puma driven plate lasts about 50k miles before the permanent set on the springs becomes sufficient to warrant replacement. Much above that and you start to run the risk of a spring falling out and making for a much larger bill.
Post #416458 15th Apr 2015 7:01pm
LR90XS2011
my clutch was replaced at 7k for rattling, it however appears they will rattle for a long time before they fail DEFENDER 90 TDCI XS,
Post #416475 15th Apr 2015 7:38pm
