![]() | Home > Puma (Tdci) > 2.2 remap |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I'm biased but it would BAS for me as I'm a dealer or bowler
![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
I can't help smile when I read all these 're-map' threads and how everyone has their favourite
![]() it would be really interesting to KNOW how different they are, not just in how much bhp, Nm they produce but the really important stuff like HOW they produce the extra, again not just how smooth they are albeit that's clearly very important but what changes have taken place to achieve the extra power, how the 're-map' has been changed to accommodate loosing the egr and not pulling up a fault. How 'tailored' are they to receive different intercoolers, air flow modifications etc etc.. Over the moom with mine but really looking forward to getting my transmission finally sorted so I can REALLY enjoy it all of the time and not just on and off when the clutch feels like playing ball. with it being the 2.2 you might want to consider this a little more closely than with a 2.4 as my understanding is you can't chop and change the 're-map' so easily. I guess the other thing is can you try before you buy ie test drive one already modified? |
"with it being the 2.2 you might want to consider this a little more closely than with a 2.4 as my understanding is you can't chop and change the 're-map' so easily."
Very true but if you have two ecu's it is a 10 minute job ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
As Bob says the easiest way is two ECUs, bought one from eBay for around £50 Then had it cloned to the car
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Just get a Bowler no issues with the ECu
I think Ken's got the right idea......other than perhaps the associated costs
![]() presumably the idea of ecu swaps and similar would then require a trip to the local LR garage for a pilot re-learn on pump and injectors? |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Hi All
At Alive we offer an Atric module which allows you switch your car to different types of maps written uniquely for you! you can even revert your Ecu back to standard with the Atric for when you are going in for a service. It can hold multiple map types so you can pick and choose how you want your car to perform in different scenarios. It also works as a fault code reader and allows you to read and clear engine management fault codes. Hope this helps Best Regards Alex Divers |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
@ Alex ,, Alive
Are you sure this is for the 2,2 ? That the Atric can stores numerous map. inc the LR standard, and can be user changed whenever ![]() Main Brian James Trailer Dealer for South West UK |
The next software update (due very soon) for our new ATRIC p3 system will support OBD port flashing of the 2.2 Defender, but the ECU will still need to be unlocked on the bench first. The device has the capability of holding up to 5 different states of tune, as well as the original factory map.
Give us a call on 01472 812900 to discuss. Take a look on our online shop too! http://www.alivetuning.com/alive-boutique/...uct_id=144 Regards, Gary. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
Heard very good things about the above on face ache. My 2.4 has an Alive tune too, it has never driven so nicely and so well behaved.
Runs well in normal driving with all the power you need for ease of pulling. But if you really need some power pulling off or towing or if you need to put your foot down for a reason. ![]() Wow, really shifts! Funny seeing some eurobox drivers having a shock when they try and overtake.n ![]() |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
The Puma 2,2 can be programed with different maps with the MPF tool once the ECU has been modified.
The MPF operates from your android phone or tablet and has space for 4 maps if required. Most only require 2. MPF = my personnal flash tool., available from BAS or one of his dealers. Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 ![]() ![]() |
I there I filled in your online questionnaire with a couple of points, one was about the Artic 3 and was a cost question on whether it was the same price as the 2.4 and the other question was about your registered outlets and where they were in the UK.
Did you get that mail? Thanks 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
For remote switching Bas have two options. The Android MPF interface seen on my site and mentioned by Cold And Wet
https://secure.bellautoservices.co.uk/stor...landrover/ and very shortly the new Apple and Android compatable model interface with many more functions and features than the existing tools on the market of which just will not compare functionally. A little more here. http://www.defender2.net/forum/post413790.html#413790 Regards Pete. |
