Home > Technical > Security - Windows.......heard something?
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Evening all,
I read something disturbing the other day about the ease of access through the defender windows... the comment didn't elaborate on what it was or how to fix it, but as the owner of a 4 month old defender, my baby and pride and joy, i'm now massively concerned that there is some tennis ball trick etc that can be performed in order to gain access and steal my pride and joy - heres hoping the missus isn't going to read this!
Obviously we don't want to advertise this, so PM me if you know how to fix it, what ever 'it' is!
M
Post #416050 13th Apr 2015 10:40pm
mk1collector
Put some internal window grilles in the back and you'll be fine Ray
My build thread
Post #416057 13th Apr 2015 11:07pm
K9F
Landyglass is another option.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #416074 14th Apr 2015 6:27am
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Gone in 10 secs
you tube it! "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #416076 14th Apr 2015 7:02am
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I've fitted mantec internal window grills
Post #416230 14th Apr 2015 7:20pm
leeds
Glass? Hammer, brick etc =broken window
OK rear windows you can use various grills. Front windows? Security films are available, am not talking about tinting film. Proper security films are available but are not exactly cheap.
Brendan
Post #416241 14th Apr 2015 7:44pm
K9F
You have to err on the side of sense and sensibility.........
Hard top.....can opener, cordless grinder = same scenario as broken glass.
Window Grills.....wire, bolt cutters = same situation....
Does the front screen also get the security film treatment, won't stop it from being popped out though?
Anything you do is just another layer nothing else. A determined thief with the correct tooling and back up equipment and it'll strill disappear relatively quickly too. Layers now matter how few may hold them up a while, and perhaps even deter them, it may also help you rest a little more restfully too. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #416270 14th Apr 2015 9:21pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Post #416274 14th Apr 2015 9:25pm
LoveTheMud
So effectively, there's nothing I can do... 😣
Well she's a pretty little thing so I guess I will just keep her well for as long as I've got her ☺️
Is there anything I can do to make her impossible to drive - I don't mean leaving her as she is, I mean in the sense that a new range is almost impossible to start without the key?
Post #416277 14th Apr 2015 9:35pm
Lambley
Tracker, removable steering wheel, x-eng lock etc, the usual stuff - don't get downhearted mate, there's lots of security available
Post #416279 14th Apr 2015 9:39pm
shaggydog
You could try taking the windows out and the refitting them using sikkaflex?
Would seriously slow down being able to "pop" them.
I also sawed off the little unlock bit on the latch which would make it more difficult to open the door if they do pop the window.
But peddle lock, gear stick lock, tracker, boxed in, and ignition shroud will all worth looking at too Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #416389 15th Apr 2015 12:53pm
grizz
I've fitted them in the rear for safety and security
Post #416453 15th Apr 2015 5:45pm
LoveTheMud
Id ask what rear visibility is like with the internal window guards... but i have tinted windows so cant see out anyway Smile
Post #416535 16th Apr 2015 12:10am
Lambley
^^^ Yep, any pictures looking from the inside outwards Grizz?
Post #416538 16th Apr 2015 4:39am
grizz
I've also fitted a full height genuine dog guard to stop anything coming in to the passenger compartment ..
I'll get some photos later .
Post #416663 16th Apr 2015 6:14pm
