Home > Technical > Security - Windows.......heard something? |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
Evening all,
I read something disturbing the other day about the ease of access through the defender windows... the comment didn't elaborate on what it was or how to fix it, but as the owner of a 4 month old defender, my baby and pride and joy, i'm now massively concerned that there is some tennis ball trick etc that can be performed in order to gain access and steal my pride and joy - heres hoping the missus isn't going to read this! Obviously we don't want to advertise this, so PM me if you know how to fix it, what ever 'it' is! Cheers M |
13th Apr 2015 10:40pm |
Put some internal window grilles in the back and you'll be fine Ray
13th Apr 2015 11:07pm |
Landyglass is another option.
Click image to enlarge Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Apr 2015 6:27am |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
you tube it! "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows." |
14th Apr 2015 7:02am |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
I've fitted mantec internal window grills
14th Apr 2015 7:20pm |
You have to err on the side of sense and sensibility.........
Hard top.....can opener, cordless grinder = same scenario as broken glass. Window Grills.....wire, bolt cutters = same situation.... Does the front screen also get the security film treatment, won't stop it from being popped out though? Anything you do is just another layer nothing else. A determined thief with the correct tooling and back up equipment and it'll strill disappear relatively quickly too. Layers now matter how few may hold them up a while, and perhaps even deter them, it may also help you rest a little more restfully too. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Apr 2015 9:21pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
14th Apr 2015 9:25pm |
So effectively, there's nothing I can do... 😣
Well she's a pretty little thing so I guess I will just keep her well for as long as I've got her ☺️ Is there anything I can do to make her impossible to drive - I don't mean leaving her as she is, I mean in the sense that a new range is almost impossible to start without the key? |
14th Apr 2015 9:35pm |
Tracker, removable steering wheel, x-eng lock etc, the usual stuff - don't get downhearted mate, there's lots of security available
14th Apr 2015 9:39pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
You could try taking the windows out and the refitting them using sikkaflex?
Would seriously slow down being able to "pop" them. I also sawed off the little unlock bit on the latch which would make it more difficult to open the door if they do pop the window. But peddle lock, gear stick lock, tracker, boxed in, and ignition shroud will all worth looking at too Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
15th Apr 2015 12:53pm |
I've fitted them in the rear for safety and security |
15th Apr 2015 5:45pm |
Id ask what rear visibility is like with the internal window guards... but i have tinted windows so cant see out anyway
16th Apr 2015 12:10am |
^^^ Yep, any pictures looking from the inside outwards Grizz?
16th Apr 2015 4:39am |
I've also fitted a full height genuine dog guard to stop anything coming in to the passenger compartment ..
I'll get some photos later . |
16th Apr 2015 6:14pm |
