Home > Td5 > Safe to remove?
Bosken
2001 Defender 110 Td5 CSW Keswick Green
Safe to remove?
I wonder if its safe to remove the 2 bars, guess its for the rear seats that i dont even have. I want to build toolboxes and stuff and they are in the way. TD5 2001 110.
Post #416119 14th Apr 2015 10:51am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
They are for the rear seat belts and seats as you said. Should be fine to remove they will be some stays attached to them under wheel arch that go to cross member aswell which can also be removed. Don't forget to plug holes in the wheel arches.
Post #416123 14th Apr 2015 10:58am
Bosken
Thanx man!
Post #416128 14th Apr 2015 11:08am
JWL
I took one side out of mine as I wanted to leave one seat in for the "just in case passenger" but in the last 6 years it's been used once so that one is coming out as well and storage compartments will be constructed.
Post #416131 14th Apr 2015 11:26am
mk1collector
Took mine out to put forward facing seats in and had no problems Ray
My build thread
Post #416132 14th Apr 2015 11:44am
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
I took mine out, but put them back as I have drawer system installed up to the height of the wheel arches and they are useful to use as tie down points when items are on top of the draws such as ammo boxes etc.
However when out they do not seem to affect the body strength. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #416135 14th Apr 2015 11:58am
Anderzander
I've just removed mine to put a forward facing seat in. What's left is no less rigid than a HT.
Post #416160 14th Apr 2015 3:01pm
