![]() | Home > Td5 > Safe to remove? |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
They are for the rear seat belts and seats as you said. Should be fine to remove they will be some stays attached to them under wheel arch that go to cross member aswell which can also be removed. Don't forget to plug holes in the wheel arches.
Bosken Member Since: 06 Sep 2014 Location: In the bush Posts: 19 ![]() ![]() |
Thanx man!
I took one side out of mine as I wanted to leave one seat in for the "just in case passenger" but in the last 6 years it's been used once so that one is coming out as well and storage compartments will be constructed.
Took mine out to put forward facing seats in and had no problems Ray
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 ![]() ![]() ![]() |
I took mine out, but put them back as I have drawer system installed up to the height of the wheel arches and they are useful to use as tie down points when items are on top of the draws such as ammo boxes etc.
However when out they do not seem to affect the body strength. 2002 110 TD5 White 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I've just removed mine to put a forward facing seat in. What's left is no less rigid than a HT.
