Home > Maintenance & Modifications > Soldering Iron choice...
Page 2 of 2 <12
Lorryman100
K9F wrote:
Would have liked to discover how you can possibly use two at once though. Wink
Solder tip on one and the heat gun tip on the other for the heat shrink Very Happy
Post #415540 11th Apr 2015 8:58pm
K9F
I use the veritable 'Mark 1' heatshrink gun for smaller 'in safe atmospheric condition' jobs........
Cheaper on gas too....... Laughing Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415543 11th Apr 2015 9:06pm
Cupboard
I had the smaller Iroda (70W?) which was fine for soldering but a bit wimpy for anything else. I've now got the 120 with the removable fuel cartridges, I find it works well although sometimes I have to give it a bit of a shake to get the gas to come out properly. The fuel cartridges leak if you leave them in the iron, so I take them out if I'm not using it for a little while.
I don't know what it is, but there's somehting in the cartridges that you can move up and down by hitting it on something. Performance seems the same wherever it is.
For desk work at work, I use an Antex which is adequate. It's fine for small stuff but isn't very powerful. At home I've got an ancient Weller soldering station I got second hand at uni and that works very well. The only issue is that Weller stuff is really pricey.
Post #415583 11th Apr 2015 10:27pm
Page 2 of 2 <12
